The cars are both 95 turbo 850s. The donor car seems to have a smaller turbo unit, and a little different engine mounts and ABS system. I notice the 'new' 95J transmission has a sensor just to the right of the info tag, a speedo sensor? which the other dead tranny doesn't have. Am I doomed or can this work??
I'd love to know before I put in new seals and drop in the donor tranny.
Original (dead) tranny from 2/95 keeper vehicle: 50-42LE 94L
Donor tranny from 12/95 donor vehicle: 50-42LE 95J 1208-840
VIN and info on keeper car (2/95)
VIN and info on donor car (12/95)
95 850 Help! Are these two transmissions swappable?
850TurboTurtle
- Year and Model: 96 850T, 05 S80T6
- Has thanked: 12 times
- Been thanked: 5 times
- Year and Model: Many Volvos
- Been thanked: 76 times
The donor car is a '96 model. The speed sensor on the '96 is not on the transmission like it is on the '95 which leads to some issues but they may be surmountable. I think you can tap a wheel sensor to get the VSS signal. There may also be a difference on the RPM speed sensor(s). If I'm not mistaken there are two sensors on the '96 (before and after the torque converter) but only one on the '95 which is the actual RPM sensor. I think you can just ignore the second sensor.
tryingbe
- Year and Model: None
- Been thanked: 26 times
My 94 Turbo 850 have a 97 auto trans which does not have a speed sensor. I spliced the speed sensor signal from the driver side front ABS system, works fine. Leave the speed sensor on the trans be unplugged.
85 GLH, 367 whp
00 Insight, 72 mpg
00 Insight, 72 mpg
850TurboTurtle
So do you just wire from the wheel ABS sensor to some other spot on the car wiring harness? The donor tranny has a speedo sensor on the housing near the stamped tag, but the old dead tranny does not appear to have any speedo sensor on it.tryingbe wrote: I spliced the speed sensor signal from the driver side front ABS system, works fine. Leave the speed sensor on the trans be unplugged.
Thanks for any details on how you do this! Very encouraging news.
(I edited this reply, because I had my tranny models confused for a sec. The older dead tranny is the one without the plug on the tranny housing.)
850TurboTurtle
Lee, Any idea where the tap from the wheel sensor should go from there? I can figure out how to tap the wheel sensor, but where do I send the signal from there? I don't know where on the 95 model to patch in the wires.Ozark Lee wrote:I think you can tap a wheel sensor to get the VSS signal.
Also, the donor tranny does have the speed sensor on the transmission housing, and the target vehicle does not. So don't I have one too many speed sensors somehow now?
And if the previous (now dead) tranny doesn't have a sensor on the housing, then where was the target vehicle getting its speed sensor data in the first place?
Thanks! Rick
- Has thanked: 311 times
- Been thanked: 817 times
It sure sounds like you may have the transmissions mixed up.
The 94-95 models have a speed sensor at the back of the trans, and a plug in the wiring harness for it. Your 95 should have a speed sensor.
All 96+ get the speedo signal from ABS sensor, usually there is no plug in the wiring harness but I am not certain for a late 95 or early 96.
If you don't have them mixed up and your 95 truly has no speed sensor: Just drop in the donor transmission and don't worry about it, you will still be getting speedo signal from the ABS as you were before. Leave speed sensor unplugged on the new trans.
If you do have them mixed up and your 95 has a speed sensor: Find the wires that connect to your current speed sensor connector plug, and splice them into the ABS sensor wires. Then install the new trans.
I've never done this but it is a well tried and true solution, commonly used for like 10 years. First worked out by people swapping in newer transmissions but also a standard practice with most manual swaps.
Be careful here. If the donor is a '95 and the target is a '96 you will have problems since the second RPM sensor isn't there on the '95 transmission but the TCU expects to see a signal from it.
Does a TCU swap fix that, drop the 96 unit into the 95?
850TurboTurtle
Thanks Erik and Lee for the great input.Ozark Lee wrote:Be careful here. If the donor is a '95 and the target is a '96 you will have problems since the second RPM sensor isn't there on the '95 transmission but the TCU expects to see a signal from it.
The donor is mfg in 12/95 as a 96 model according to VIN. The target is a 2/95 mfg and a 95 model year.
I think I have my sensors mixed up more than anything. On the dead 95 tranny there is a wide rectangular plug area beside the pax side axle hole. No such thing on the 96 donor. On the 96 donor there is a 1/2" round sensor on the top of the tranny just a few inches back of the stamped tranny info plate. Photos:
rectangle sensor on dead 95
round sensor on donor 96
It might. Both cars should have had a Motronic 4.3 ECU so it should be able to talk to either TCU. I've never tried it.erikv11 wrote:Does a TCU swap fix that?
- 15 Replies
- 901 Views
Last post by vtl
- 503 Views
Last post by CIK7
- 699 Views
- 869 Views
Last post by PIZZABYSTORMED
- 759 Views
Last post by JRev
