Hello all;
Does anyone know either the part number or perhaps a website that would sell the copper end fitting that attaches the right front pass. side brake pipe line to the brake hose?
My friend and I were trying to do a simple job the other night and replace worn out front brake hoses and in the process, my friend rounded off the copper fitting that is on the opposite side of where the steel end of the brake hose attaches. He said there is enough slack in the overall length of the tube run to just cut off the end and add a new fitting. (He has the end-bulbing tool)
Not sure who can sell me just the end fitting.
Thanks!
1998 S70 Copper End Ftg. on Brake Pipe
Mr. Detail
- Year and Model: 2002 V70 N/A
- Has thanked: 157 times
- Been thanked: 6 times
- Has thanked: 2199 times
Quick question kahl. The parts would appear to be Imperial sized and not metric from your picture, or is this just an example?
Why is it always the right rear??1
both of my p80s have stick rear calipers at this point
'92 945 Turbo, 13lb boost on E85 with 54lb injectors, 230k
'98 V70 N/A 174K , Konis Sport + H&R Blue springs,16 inch Solars
'97 855 N/A
Previous: Honda Fit Sport (RIP), Kymco S200 (missed),
'86 244 DL M46 (restored and traded)
'97 855 N/A
Because thats the slushy side of the salt, water, and ice that gets sprayed up by the right Front..mika wrote:Why is it always the right rear??1both of my p80s have stick rear calipers at this point
kahl
- Year and Model: 2000V70XC
- Been thanked: 10 times
Neil, thank you for pointing this out. The imperial worked fine with no seepage. After seeing your post I went over to NAPA and got the exact size wich is a M10X1.0. The nut is made by SUR&R part number is BR230. The brake pipe line size was 3/16.
- image.jpg (158.24 KiB) Viewed 1171 times
Mr. Detail
Thank you "kahl" for that beautiful attachment! You should take my moniker as the new and improved "Mr. Detail".
