Hello,
Does anyone happen to know the tap size and thread pitch of the hydraulic return port on an 850 steering rack. Cannot thread the fitting into the port of a brand new rack, thinking there may be a burr on one of the threads. Looking at it under the car, the threads look fine but the fitting threads in a turn or two, than can't turn it anymore. I'm going to remove the rack again and check it further, thinking I might have to chase the threads with a tap. I'm guessing they are pipe threads.
Thanks!
1995 850 size and thread pitch of steering gear port
You should be able to see the taper on a pipe thread - look closely at the loose fitting or even put a straight edge on it. I haven't been into a rack in a long time but I don't recall seeing pipe threads used here.
efkaba
- Year and Model: 850, 1995
Thanks, I believe you are correct, it doesn't look like pipe threads. I don't have a thread gauge or a caliper to measure. Saw Autozone has a thread restorer kit on the tool loan program, probably have a tap that would work. Only have to clean the first couple threads.
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
to those who may know.. Is there a different port on the SMI vs TRW racks?
Current Volvos:
- Has thanked: 311 times
- Been thanked: 817 times
I have a TRW rack out of the car, but maybe you (OP) do now too. Let me know if I can measure something for you.
- 9 Replies
- 13010 Views
- 11 Replies
- 19452 Views
Last post by volvolugnut
- 9 Replies
- 3753 Views
Last post by xHeart
- 14 Replies
- 4699 Views
Last post by 98v70dad
- 23 Replies
- 6735 Views
Last post by MrAl
