1995 850 engine cranks but won't turn over
Svenska
Year and Model: 1995 850 GLT
Post by Svenska »
I can't figure out why my '95 850 non-turbo won't start. I just replaced the plugs (Volvo-brand) dist. cap & rotor (Bosch) and plug wires (Bosch). I also replaced all the motor mounts/torque rod because they were all collapsed. The fuel pump is working because I'm getting a fuel smell @ the engine bay area each time I try to start it (actually I'm flooding it, I know). I took each plug out and checked for spark which I do have (I placed each plug one-at-a-time on the engine while plugged into the respective wire). I even replaced the camshaft pos. sensor with a used but known good one. The engine just cranks but won't turn over. It ran fine yesterday, nothing out of the ordinary happened. I also pro-actively replaced the ignition coil (Bosch) today since the one in there is 20 years old. Thinking it may be defective, I swapped the old one back in - still nothing. What am I missing?
Has thanked: 1613 times
Been thanked: 4078 times
Try a 1-2 second shot of ether ( starting fluid) into the air cleaner and see if you get some fire
This gives you a clear indicator of spark vs fuel problem.
A compression test is the next step after that.
RussB
Year and Model: '00 S70, '04 S60
Has thanked: 3 times
Post by RussB »
Just to be on the same page, when a car "cranks", it IS turning over. They are synonyms
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Post by FLXC90 »
and don't totally freak at the thought of compression test, it was running before, right? Lookup "lawnmower syndrome" here and see what is suggested. But spark, fuel, and compression are what a car needs to run.
Another thing to check is to double-check spark plug wire order, one of the manuals has it wrong. Check database for that under basic tune-up. Might check that first, no-cost, simple.
Current Volvos:
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
As said, the Haynes manual has the plug wire locations totally wrong and even the Volvo factory manual has the rotation backwards. If you look carefully on the cap the cylinder associated with each of the ports is molded into the plastic but the numbers are very small.
