The oil tstat is for the oil cooler and does not cause this issue of no oil pressure.
Perhaps you may want to drop the oil sump and look to see if the pick-up screen is clogged.
1997 850 GLT, No oil pressure
- Has thanked: 1613 times
- Been thanked: 4078 times
I've never gone this deep into a Volvo block, but the classic move on a VW is to reassemble the engine and leave the gears out of the oil pump...
- Year and Model: Lots
- Been thanked: 128 times
I can't help but think that the bearings are not clearanced properly. Did you use plastigauge to clearance them?
Other than the above did you install a full o ring set for oil feed and ensure the pick up tube has a new one?
Found the issue, apparently when I sent the oil pan in to be cleaned an air valve, part # 463963, was removed which I hadn't noticed. With it gone oil just drained back into the pan and didn't allow for any pressure. Got a new one and everything is fine. Thanks for the help everyone.
Wow. This one needs a bookmark and obscure problem of the month award
Well done figuring that out, had me stumped
- 1520 Views
Last post by Salomons Driveway
- 2367 Views
Last post by fitz548
- 2312 Views
Last post by JimBee
- 1410 Views
Last post by crussell83
- 10 Replies
- 4642 Views
Last post by tryingbe
