1999 S70 Non-Turbo. Manual Climate Control.
I've never had the strongest blowout of AC...
Recently, my indoor/outdoor air button stopped working. Always kept the button on.
Problem:
-Hot outside air blows out of the vents whenever Im driving, whether or not the IN/OUT button is on. When I turn the ac on, I get cold ac.
-With the AC on at idle at level 1 or 2, sometimes 3, isn't really much. Accelerating the car makes it blow out more.
My AC has never not blown out.
Do I need a new blower motor? New climate control?
99 S70 n/a. Can somebody diagnose my faulty Climate Control?
- ashlee2319
- Year and Model: 2000 V70 NA
- Has thanked: 3 times
- Been thanked: 2 times
2000 V70 N/A
1999 V70 GLT - Current project car
- Been thanked: 4068 times
You should get cold air with the recirculate button in either position, this button just chooses if you cool air from the cabin or from the outside. Volvo AC is quite good, but like all other things on a 17 year old car, things break.
On the climate control, the culprits are:
Compressor clutch ( easily fixed with the bread clip fix or zip ties)
Blower motor
AC Evaporator core ( buried under the dash, 10 hours of labour to get to)
Blower motor
- ashlee2319
I'm saying that before, I would never have air blowing out of out my vents with the recirculating button ON. Now I do. My ac always turns on , I never have problems with the clutch.
I'm just wondering is this issue related to a soon failing blower motor ? Or the actual climate control unit?
2000 V70 N/A
JRL
- Year and Model: Several
- Been thanked: 16 times
There will probably be a stored code in there, get it read
It's a climate unit fault. Air should flow from the selected vent regardless if the recirc button position, so you probably have multiple problems nowashlee2319 wrote:I'm saying that before, I would never have air blowing out of out my vents with the recirculating button ON. Now I do. My ac always turns on , I never have problems with the clutch.
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
OP stated that this is MCC. No Codes.JRL wrote:There will probably be a stored code in there, get it read
Just noticed its Manual climate control so no codes on MCC
Shut engine off, key on to position 2.
Turn your fan speed up progressively through the speeds and listen to see if the blower ramps up,accordingly to troubleshoot.
- Has thanked: 2202 times
Are these cable operated from the adjustment controls? I know that in some of the older generations of Volvos these cables could come loose or connections to the flaps would break. I have never seen an MCC P80 in all my visits to PnP. Maybe we never got the choice up here?
- 701 Views
Last post by shiloh51933
- 9 Replies
- 1133 Views
Last post by foggydogg
- 6073 Views
Last post by misha
- 2775 Views
Last post by Legofan
- 1291 Views
Last post by wanderdüne
