1999 S70 Oil leak from bolt in timing belt housing
- Has thanked: 2205 times
No idea, sorry. But you also appear to have oil leaking from the left (As viewed) cam-shaft seal. Looks like a small trail of oil under it.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
I doubt that bolt is leaking. You can pull it and see if any oil comes out. If it has a gasket, replace it.
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
http://www.volvopartswebstore.com/image ... -76765.jpg
could that be the valve at index-6?
Current Volvos:
Thanks guys, I should have explained the engine in the picture is not mine, only used to show position of bolt. Cleaned around the offending bolt and started the engine. Could see the oil seeping out from around this bolt. It's slightly hidden behind the rear timing cover plate, but I will try to pull it and see what needs to be replaced as suggested by rspi.
Just an update on the problem. Bolt in question was loose. Tightened and no more leak. Had to cut away a small portion of the rear plastic backing plate to gain access, but not too big an issue. If you have a leak running down beside the turbo oil feeder banjo bolt on the engine block, then keep this in mind. Thanks Guys. P.S. Thanks Jimmy for your post. Good to know what the part is and it's purpose.
- 1278 Views
- 5333 Views
Last post by jimmy57
- 16 Replies
- 7181 Views
Last post by erikv11
- 9 Replies
- 2461 Views
Last post by cn90
- 825 Views
Last post by difflock54
