My 1998 V70 GLT Rebuild Project
obayha
Year and Model: V70 1999 Base
Post by obayha »
I have been looking at your bend and pull project and was wondering if a replacement piece is possible. I am not sure how straight you can get that in order to attach the fender and have everything line up. A clip could be cut from another car and welded without much of a problem. That area looks pretty mangled.
Shane
1998 V70 T5 331,000 :( Her last day was on 3 cylinders.
New to me 1999 V70 NA 163,000 Now at 217,000
2006 V70 2.5T in driveway (WIFE'S)
1982 Toyota FJ40 Land Cruiser
101
Year and Model: 98 V70GLT, 98 S70T5M
Post by 101 »
Lakeview Auto Parts in Charlotte was where I sourced a 1998 Volvo V70 sunroof assembly back in 2012. Might be worth a look to see if they are still around and still deal in Volvo parts.
101
1998 white V70 GLT 230K "Elsa"
1998 white S70 T5m 180K "Anna"
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
That's what I've been concerned about. I think I'm going to see how everything lines up, and if it's still a problem, I'll look into getting a new piece welded in.
obayha
Post by obayha »
bmdubya1198 wrote:That's what I've been concerned about. I think I'm going to see how everything lines up, and if it's still a problem, I'll look into getting a new piece welded in.
I was looking at that area on mine last night, as the fender in no longer on it. If you can give me an idea of what you might need I can cut larger and I will have it on hand, even if I get rid of the rest soon.
Shane
bmdubya1198
So I chipped some of this crap off my passenger side mud guard today. Don't know if it was wet tar that splashed up (there's some on the wheel wells too) or some kind of adhesive. Really nasty.
Even though the bottom is a little hacked up, it's still in good shape, I think I'm going to sand it down and repaint it. Pretty sure those two slots/holes are supposed to be there. You guys think I should I match it to the car or just do flat black?
obayha
Post by obayha »
I am bringing you the one from my right side. May be in a little better shape. Not by much. Two hole are for draining, I think.
Been thanked: 504 times
Post by cn90 »
OK,
I just got back from the Post Office, for the following items, it will cost me about $30 to ship to Charlotte NC. As mentioned previously, the L turn signal assembly is brand-new (aftermarket but excellent quality).
Anyway, all I ask is $50, FREE shipping for all the parts below:
- Air bag in pristine condition.
- L turn signal (you may or may not need this): brand new
- Left Front door actuator
- L headlight assembly OEM Volvo.
If you want these, PM me...
bmdubya1198
obayha wrote:I am bringing you the one from my right side. May be in a little better shape. Not by much. Two hole are for draining, I think.
Probably be easier for me to repaint yours, then. At least it shouldn't be coated in that tar stuff.
bmdubya1198
cn90 wrote:OK,
I should be getting most of the parts I need from obayha, but I'll let you know if I end up needing that turn signal and door actuator. The left turn signal seems to be alright, but there's a clip or something damaged.
obayha
Post by obayha »
Saw the project car today after work. It very much looks do able. Clean, tinted windows and looks to be maintained. Owner said it had some recent work done on top end and turbo. That's a plus for an engine with 160,000 plus on the odometer. If they get past that wrinkle with the fender, I think he will have a good ride at a reasonable price.
Good luck with it and I will see what else I may have for the remodel. :D
Shane
