96' 850 GLT Long saga of P0140 P0133 MVSOLVED
On the receipt, the rear 02 is listed as Part#9202720, priced at $274.97. That makes is "seem" as though it's the genuine Volvo 02 Sensor but that doesn't mean that's what they actually installed and replaced, under warranty. That warranty is up, so I won't get another free replacement of the 02 sensor. Checked for Vacuum leaks again and didn't find any. From underneath, the Exhaust manifold looks pretty warn. It could indeed be an Exhaust Leak. I was planning to replace that, anyway....
96 Volvo 850 GLT/NA-Green @312,298 miles
Stage 0 Tuneup w/Cold air side/open flap air box mod
Pro Parts Sweden Exhaust manny/DEC Cat/Starla Exhaust/SS Tip
Hard Rock guitarist with Solo project, driving a Swedish Death Metal Machine. http://darkblu.com
Ben850
- Been thanked: 7 times
On my '96 855, I had found a broken hose at the rollover valve. Search this site for the info.
Directly in front of the right rear wheel.
The fuel filter is next to it. Replace it while you are there. It is easily accessible In this year.
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
- Has thanked: 311 times
- Been thanked: 817 times
OK that price is right in the ballpark for a genuine Volvo sensor (which is Bosch, of course) from the shop. Pics would nail it down but sounds likely.
welcome to your new hobby. Most of us have not seen a real mechanic since we got our cars. If you run into a problems you cant repair yourself (such as an engine rebuild), time for a new (old) Volvo. Most stuff is better to understand yourself, like the vacuum linesDARK_BLU wrote:What makes me mad is that it took me maybe 10 minutes tops to find this disconnected hose and I am not an ASE Certified mechanic. These guys at Peachtree Imports had this car overnight numerous times in March and April and never checked for or noticed this disconnected Vacuum hose, then go straight for "It might be the ECU and that's expensive", when I could've gotten a used ECU from Voluparts for $125, installed it myself, and it's plug and play on my 96 850 GLT/NA? I'm never going back there again. I will be replacing the plug wires, plugs, and Ignition, MYSELF.
Thanks again, guys!!
'92 945 Turbo, 13lb boost on E85 with 54lb injectors, 230k
'98 V70 N/A 174K , Konis Sport + H&R Blue springs,16 inch Solars
'97 855 N/A
Previous: Honda Fit Sport (RIP), Kymco S200 (missed),
'86 244 DL M46 (restored and traded)
'97 855 N/A
The next step would be monitoring the rear O2 sensor to see if the output is doing. This will separate sensor from wiring issues. An exhaust leak can generate a these codes you are seeing, as can a vacuum leak.
After all spring and summer of the CEL coming on and my code reader telling me P0140/ rear 02 no activity, it finally just stopped giving me the CEL. No idea why it stopped but glad that it stopped. We can close this thread now.
IT finally figured out resistance was futile...
If it comes back, may I suggest some black masking tape? I read through your thread and did not notice any problems with how the car drove (beside the MPG). Issues will come up with the car at 300k, but I do understand certain states will not pass inspection with a CEL
'97 855 N/A
'97 855 N/A
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
Now you have a stage 0 850 with over 300k, get your longevity badge from VCOA and bend some strings
Current Volvos:
Indeed. She skeets tires in second gear at over 307,800 on the Odometer :-D
- 2291 Views
Last post by adamdrives
- 1525 Views
Last post by E Showell
- 1129 Views
Last post by theWIFES_S70
- 684 Views
Last post by snowisgr8
- 989 Views
Last post by shiloh51933
