1997 850 glt Serious Engine Smoking Upon Deceleration
- Has thanked: 311 times
- Been thanked: 817 times
Oh sorry yes, will work just fine with re-flashing, sedan or wagon makes no difference on the ECU. Any 98 turbo ECU, GLT or T5, is ready to be flashed for an 850 turbo.
1ezliving4ume
- Year and Model: 850 glt turbo 1997
I'm going to pull a part right now! Thanks
1ezliving4ume
Ok, here is what I have. White injectors and a ecu out of a s70, T5 1998. Starting to come together.
I now have to figure out how to flash this ecu or get someone to do it for me......hint.....hint. I'm going to start cleaning everything up, replacing all vacuum lines that look even remotely bad. I also still need the gaskets to install the 15g turbo. I wonder if I should have it checked out. all seems fine but I'm no turbo expert so, I try to find a place to look at it.
The machine shop said it will be atleast a week before my head is done so I have some research time.
1ezliving4ume
Ok, I have my vin but don't understand how this tells me if my car has a 4.4 or 4.3?erikv11 wrote:A 97 850 is either Motronic 4.3 or Motronic 4.4, you have to check the VIN to find out (http://new.volvocars.com/ownersdocs/199 ... n1997.html).
Regardless though, I am pretty sure that for your 850, any V70 ECU (well, any 98 V70 turbo ECU) would need to be reflashed because of the AC issue mentioned above. The pinouts are different in a 98. But if it is a 98 T5 then grab the ECU, it will work great.
1ezliving4ume
Ok, I figured it out I have a 4.4 so do I have to flash the ecu? and if I do do I do it in the car? wouldn't that burn up my climate controller? I'm lost on this stuff.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
We are talking about T5 here.There is no Motronic 4.4 in '97 850 T5.erikv11 wrote:A 97 850 is either Motronic 4.3 or Motronic 4.4...
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Well you are only talking about T5misha wrote: ... We are talking about T5 here.There is no Motronic 4.4 in '97 850 T5.
Another easy thing to remember it is that every 850 with an air pump is m4.4. Turbo, non-turbo, whatever if it is an 850 with an air pump then it is m4.4. And ALL 98 S/V/C 70 are 4.4.
The ECU re-flashing is complicated to learn because there are 10,000 pages of instructions for one pretty straightforward task, but then easy to do once you have figured it out. The best thing for you to do if you are changing ECUs and the hardware is to get a spare turbo ECU (any will do as discussed) and flash in a fresh 98 T5, m4.4, with the AC modification, and drop it in your 850. Keep the old ECU so you have it, I am confident enough in the tunes to use them but not enough to throw away the original ECU. I will respond to your PM.
Missed your earlier post about the ECU: that's a good one, a 451 ECU. And those are the matching white injectors, yep.
http://www.ipdusa.com/products/7758/115 ... -1994-1998
1ezliving4ume
Well, I'm getting there! I appricate all your help and knowledge. I will be sending you the ecu shortly. I'm also going to get the cord so I can play around with the tuning after i get it running again. I don't know how much I'm going to get done this weekend, Its a holiday after allerikv11 wrote:Missed your earlier post about the ECU: that's a good one, a 451 ECU. And those are the matching white injectors, yep.
1ezliving4ume
OK, Thanks erikv11 the package is in the mail
Monday or Tuesday it will show up. I've be busy rebuilding the turbo. I got word on my head job<-I like saying that
265.$$ with 5 new valves. This is a valve job and replaneing. Cams checked out ok, GOD I LOVE BEING IN THE RACING CAPITAL OF THE WORLD! Indianapolis, IN. baby.
So here were I'm at with the turbo, and yes its getting a rebalance. This car is going too....
Im waiting n my rebuild kits and a manual boost controller this week, I can't wait. No cracks in the waste gate.
- 11 Replies
- 2269 Views
Last post by wizechatmgr
- 1020 Views
Last post by mika
- 711 Views
Last post by erikv11
- 41 Replies
- 6726 Views
Last post by Seaway
- 1140 Views
Last post by vtl
