So, I've been away from the S70 for a while -- new job keeping me busy. Once I get the cockpit trim back in place and the SC-901 installed, it still needs new control arms and inner and outer tie rod ends. The outers are pretty well rusted in place. Can't budge them after lots of PB blaster and a decent amount of torch time.
Here's the question. If I am replacing the inner tie rod ends anyway, does it matter that I can't remove the outers? Can't I just remove inners and outers as a unit?
I know that I won't be about to count the turns and preserve alignment if I can't remove the outers separately, but if I'm going to have to get an alignment anyway, and can use the total length of inners and outers together for approximate alignment, can't I just remove inner and outer tie rods as a unit?
'99 S70 Outer Tie Rod Ends Rusted In Place
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- Been thanked: 4071 times
No reason to waste your time removing them from your soon to be discarded parts
It might be worth the fun to stick the tie rod end into a small container of old ATf and gas mix for two days to see if test unfree see them. Acetone is even better than gas, if you have it lying around.
- E Showell
Thanks, Steve. Will keeping the tie rod ends together pose any interesting problems in removing them as a unit? I've seen that a rubber boot needs to be cut back to facilitate removal and was wondering if keeping the outer tie rod end in place will interfere with that.
'95 855 auto (sold)
'95 855 auto (sold)
Plenty of room to pull the boot down in this pic stolen from mattymoos rebuild thread
- image.jpg (152.3 KiB) Viewed 1165 times
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
You can definitely leave the outer attached to the inner if you're going to replace both.
I did it that way in the write up linked below and it worked well:
https://www.matthewsvolvosite.com/forums ... =1&t=58194
- E Showell
Thanks, Jason. I may chicken out and leave the inners in place (110,000 total on the car), but I'd have to be able to get the outers off to do that!
'95 855 auto (sold)
'95 855 auto (sold)
- jreed
Agreed. If your inners are as good and tight as mine were a couple years ago at ~165k miles, there is no reason to change them. I replaced the inners on mine because I couldn't tell if they were good (due to my inexperience) and I didn't want to have to go back in and replace them later and have to take the time to do two wheel alignments.
- E Showell
Already got the boots.
'95 855 auto (sold)
'95 855 auto (sold)
- 12 Replies
- 2919 Views
- 2737 Views
Last post by manovlov
- 567 Views
Last post by dairyqueen814
- 728 Views
Last post by vtl
- 12 Replies
- 2989 Views
Last post by erikv11
