04 C70 VVT Oil Seal Leak
cuhfs
- Year and Model: 850,XC70,XC90,S60,80
- Has thanked: 17 times
- Been thanked: 31 times
I have what I think is a VVT exhaust cam seal oil leak after I redid the head and installed the cam cover. I installed the VVT front Exhaust seal (in timing belt area) so the outside edge is just at the point there the inside beveled edge of the cam shaft gets flat. Pushed in about the same as the back seals which are fine. Again, seal is pushed in just at the inside of bevel. First I had a major leak there and found the seal was off after cam cover install. Now I have a small leak still in the timing belt area and I think it is still from the exhaust VVT Seal. Seemed like I had installed it correctly 2nd time but still leaking. Any tips would be great.
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
04 XC70 Auto (gone)
04 C70 Convert (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
- Been thanked: 504 times
The thread below may be helpful for you. Read the posts by jordank:
http://volvoforums.com/forum/volvo-xc90 ... 251/page2/
cuhfs
Many thanks. Yes I saw that link and it appears that the seal goes just at the inside bevel. So That's where I put mine too. Not sure why I have a leak still in there. Gonna have to take that vvt exhaust cam gear off again. Any other thoughts or ides are welcome as I hate to do this a third time.
04 C70 Convert Auto
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
cuhfs
about 120K. long story is... I had the bent valves and head redone due to a busted serpentine belt that wrapped around the crankshaft which caused it to skip time (but thats another story....) anyway, Putting it back together now and am dealing with the small leak. First leak was big and was due to my not checking the seal when I closed the cam cover. so I when back in and put new seals in correctly, this has left me with a small leak. I see oil puddling in the timing belt area and some white smoke off the back of engine (which I hope is from these leak. I will go back in again and check the exhaust VVT seal and hope that maybe the edge rolled or something causing a small oil leak.
I welcome any suggestions, tips, thoughts... hopefully the third time is a charm.
04 C70 Convert Auto
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
- Has thanked: 2199 times
What brand of seal did you use? The wise guys here will tell you brand is very critical for these parts. If you have used one of the recommended brands, then perhaps there is a rough edge where the seal goes in that is nicking the seal. I had to redo the oil cooler seals after the dealer mechanic failed twice to stop it leaking. I went out and bought new oil cooler pipes as I was told that was the only way to sure it. Found there was a rough edge and the seal was getting cut when fitting. Removed it an all was well. Pipes went back!
cuhfs
I only use Volvo Brand. Except for once... when I used another brand of Serpentine Belt. Yuk.
I will check that the surface is smooth, thanks for the advice.
04 C70 Convert Auto
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
cuhfs
Needed to reset the seal. All good.
04 C70 Convert Auto
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
- 9645 Views
Last post by tyguyc
- 29 Replies
- 5837 Views
Last post by precopster
- 1120 Views
Last post by cuhfs
- 11 Replies
- 21388 Views
Last post by beoutside
- 5166 Views
Last post by LT South Africa
