1994 850 temperature gauge goes up, won't start
Sommerfeldt
Year and Model: 2018 S90 T8
Has thanked: 55 times
Been thanked: 42 times
Re: 1994 850 temperature gauge goes up, won't start
Post by Sommerfeldt »
misha wrote:Not the part with removing ecu...the part with NOT insertion it fully. :mrgreen:
Ah. Sorry. :D
- S
[Sold] '97 S70 T5
charlie33
Year and Model: 850 95
Post by charlie33 »
The socket for the ecu is like a big scart socket all i was doing was making a different contact than the one for 20 years I have now cleaned the units individual spikes and it is fully inserted but it didnt start however i took it out and gave it a flick ( not hard ) put it back in and it started so surely its the ecu if your brave take out the ecu of a 94 95 850 2.0 or 2.5 and put the ignition on 2 if the temp gauge does the same as the video ( which mine does when its out or when it feels like it when its in ) then surely its the ecu the trouble is the nearest one on ebay is latvia I am hoping im right as no mechanic or expert takes any notice of the video when the temp gauge does that, it does not start there is no power to the cps or anything else it has been checked I hope this helps someone as its cost me a fortune in time of work and i am still hoping that a replacement v.2 siemens will work everything else has been replaced if anyone can get a v.2 that would be great
misha
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
Charlie33....do what you want to do,it's your car.
You didn't do most important things like measuring ect values when it will not start.
Fluctuating temp needle ALWAYS means that ect is bad.
It can also be bad intermittently.
Removing or reseting ecu ALWAYS means that ALL values are going back to factory settings.Gathered parameters are stored EVERY time the key is removed from ignition or every time the engine is switched off after driving.
After a while....when ecu gather parameters from ALL sensors it figure out that ect signal is missing or bad and it will not start again.
Thats why it always starts when you reset ecu and will not restart.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
charlie33
Post by charlie33 »
The needle doesnt fluctuate when the car is running it only fluctuates when it wont start as the video shows also when it does what the video shows there is no values to test as there is no output to anything maybe i should change the ect but I dont think thats the problem thanks for all the input.
