1996 850GLT Replacing Rear O2 Sensor
osmium
Year and Model: 96 850 GLT
Post by osmium »
I'm in the middle of replacing my rear O2 sensor. Car is up on stands all ready to go.
When I went to disconnect the electrical connector, I found that it had an extension. The wire on the new sensor is long enough to reach without the extension.
What's the reason for the extension? The wires on it are frayed, probably what's caused the code in the first place.
Is there any reason I can't just connect up without the extension.
Thanks,
-Os
1996 850 GLT 262k miles (gone :( )
1999 Honda Civic (gone)
1996 850 GLT (gone, no more Volvos :( )
2000 Buick Park Avenue (gone)
2005 Honda Odyssey (gone)
2013 Lexus ES350 (replaced Volvo 850)
2021 Honda Pilot
Has thanked: 312 times
Been thanked: 818 times
The extensions are a genuine Volvo part and are prescribed for replacements, the outside air signal that the sensor uses comes in through the wiring sheath. The extensions basically allow for there to still be wire that is not all covered with oil, e.g. when there is a leaky turbo. They are not required, in your case I would bypass one that is frayed.
osmium
Post by osmium »
OK, thanks for the info. Don't have a turbo.
2021 Honda Pilot
Scholz
Year and Model: 1998 S70T-5
Post by Scholz »
A glt model without a turbo?
mecheng
Has thanked: 15 times
Been thanked: 21 times
Post by mecheng »
Only in 1997 the GLT got the LPT, it was the first year for the low pressure turbo.
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
osmium
Post by osmium »
Scholz wrote:A glt model without a turbo?
It's a 96 GLT.
2021 Honda Pilot
