1998 V70 XC Another fuel pump thread!
TK101
Year and Model: V70 XC 1998
Post by TK101 »
I attempted to post in another thread, but I think the thread was too old.
Howdy all, I have a few questions about this job.
First, about the car.
1998 V70 XC, White on Oak, just did PCV, all vacuum lines, fuel filter (which I did from the port-holes in the cargo bay!) plugs, wires, and a bunch of other random things that need fixing.
I did check the Fuel Pressure Regulator, it is not torn or leaking.
I have silicone hoses for the TCV on the way.
I cleaned the PTC.
I have Delrin subframe bushings to go in, but i'm waiting on new volvo OE bolts to get here from IPD.
Has anyone replaced the sending unit on the Drivers side?
Where could I even get this part?
I am looking at these fuel pumps :
http://www.fuel-pumps.net/5ca3351hp.html
http://walbrofuelpumps.com/volvo-v70-19 ... -2-4l.html
If I got that route, I am debating purchasing the scan tech assembly as well,
https://www.fcpeuro.com/products/volvo- ... -9470674-1
So I have something to practice on, possibly replace the scan tech pump with the walbro, in the scan-tech assembly, so that I can just swap when I drop the tank and subframe.
I will eventually be putting a 4t4 on this car, is it worth upgrading to the walbro?
I have read through this thread :
https://www.matthewsvolvosite.com/forums ... =1&t=20367
and I did not see anyone replacing the drivers-side assembly.
TK101
Post by TK101 »
Because I am lazy, I will simply list all the parts I have bought and installed from IPD recently.
ITEM# PRODUCT DESCRIPTION
106723 * SPRING HOSE CLAMP 7/16 IN
113200 HOSE 5MMID BLUE SILC 1 FOOT
121611 HOSE 5MMID RED SILICONE 1 FOOT
121914 HOSE 5MM I.D. GREEN SILICONE 1 FOOT
122040 TCV SILICONE VACUUM HOSE KIT P80/P2 RED BLUE GREEN
101472 SEAL VALVE COVER CAP VOLVO
120147 SUBFRAME BUSHING BOLT P80 P21998
109422 VACUUM ELBOW 850/70 STEPPED
109556 VACUUM ELBOW SINGLE SIZE
109425 VAC ELBOW KIT 850/70 11/95-98
121466 RUBBER MOUNT GROMMET FOR AIR FILTER HOUSING
112864 ORING HEATER CORE
124307 HEATER CORE 850/701994
120323 HEATER PIPE KIT WITH FIREWALL JUNCTION
113604 CLIP WIPER HEADLAMP NOZZLE
113605 CLIP WIPER HEADLAMP NOZZLE
110647 WIPERS HEADLAMP C70 S70 V70
121916 MAHLE POLLEN FILTER 91712961998 VOLVO
120741 GEAR SHIFT KNOB AUTO 8501994
104289 PLASTIC MATS BLACK F 850/70 FITS C70 ALL YEARS
102109 PLASTIC MAT 850 LFT REAR
102110 PLASTIC MAT 850 RT REAR
104290 PLASTIC MATS BLACK R 850/70 NOT FOR C70 REAR
120897 GROM USB / BLUETOOTH UNIT FOR 1994-2000 850/701994
115382 LAMP DOOR CSV70 ROUND CORNERS
114249 BUTTON ALARM FOB PANIC RED
103109 DSH CVR S70/V70 981994
124482 HELLA YELLOWSTAR H1 BULB YELLOW
115608 KEY FOB 4 BUTTON DARK GREY MUST USE WITH INCLUDED BUTTON SET
115261 POLY FIREWALL MOUNT BUSH KIT FITS 870 CHASSIS 93-2000 WITH EARLIER STYLE MOUNT.
103214 * 2B1850 ENGINE MOUNT SLEEVE SPACER/SLEEVE .75 OD X.397 ID X 2.325 LONG
103215 * 2B1850 1/2 TOP ENGINE MOUNT
111038 BUSHING UPPER ENG 850/70 -98 USE PI-213
124260 WINDSHIELD WASHER RESERVOIR CAP - P80 850 S70 V70 C70
112863 AIR DUCT 850 701998
110127 ENDLINK HD FRONT 870 P1 P3 PI-385
TK101
Post by TK101 »
Scored some Borbet
Scored some XC
What is wrong with this picture?
Ah, that looks better
The crew.
My HOA loves me
Has thanked: 2207 times
Been thanked: 1852 times
There are only 2 ways to replace the fuel pumps:
1) remove the rear passenger seat and cut a hole in the floor on the side you need to access near the pump, replace the pump as you are doing with an after market unit (you can't easily run the fuel pump cables up to the car when replacing the OE pumps as they run over the top of the tank which is not accessible),
OR
2) Get ready for a lot of hurt and drop the rear sub-frame. Read my on-going thread on the subject on replacing the rear sub-frame 'fun' I am having. I have also posted a thread on fuel and emission line routings for my car. 98's AWDs are just a little different.
TK101
Post by TK101 »
I am reading your thread now.
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
The fuel pump inserts that you linked to will not work with an XC. The fuel pump assembly is dramatically different between the AWD versions and the FWD versions. On my car the OEM pump insert was a Walbro but I could not find a match to it anywhere and it must fit exactly into the housing to work.
As a result of the lack of a suitable insert I wound up buying an aftermarket assembly. I can't remember the brand but I'm pretty sure it wasn't Scan Tech. The floor cutting technique is the way to go and it is remarkably easy with a Dremel tool with a cutoff wheel. I cut across the bottom rather than the top to try to better retain some of the vertical stability.
TK101
Post by TK101 »
I just sanity-checked myself on that walbrofuelpumps.com site.
If you chose a 1998 Volvo, it says get that one pump.
Which is obviously incorrect for an AWD.
I'll order the OE from fcp Euro.com
The pump on the drivers side (LH side) is not the main fuel pump. There are 2 pumps in the AWD fuel system as Volvo made a tank that is like a pair of saddlebags to be able to fit over the prop-shaft.
The RH pump measures fuel level as does the LH and the car figures out the overall level. The LH pump pushes fuel to the RH side, and the RH pump pushes the fuel into the fuel filter and then to the engine.
What makes you think you have a fuel pump issue in the first place? Have you checked the pressure of the system? Should be around 43psi or higher.
TK101
Post by TK101 »
The 98 only has the one pump if I am not mistaken.
And yes, I checked the fuel pressure at the pump with a hot-wired relay, 10psi.
TK101
Post by TK101 »
I have access to a lift, so I will be dropping the subframe.
Here is what is in my cart at FCP :
https://www.fcpeuro.com/products/volvo- ... wd-9470674
https://www.fcpeuro.com/products/volvo- ... 70-3501322
https://www.fcpeuro.com/products/volvo- ... al-9447179
Is there anything else I should go ahead and purchase?
Any service that should be done while I have the subframe removed?
Edit - Aha!
Found the drives side!
https://www.fcpeuro.com/products/volvo- ... wd-9470840
