1999 V70 T5 Turbocharger wastegate adjustment
This topic is in the MVS Volvo Repair Database » 1999 V70 T5 Turbocharger Wastegate Adjustment
Has thanked: 1502 times
Been thanked: 3817 times
Volvo Repair Database 1999 V70 T5 Turbocharger wastegate adjustment
Well, technically its a wastegate actuator (WGA) adjustment (for erik) :D
Following the document in the VRD and using the IPD turbocharger tool
You have to be careful to get the right pressure at the time of adjustment as the pressure slowly (over 10 minutes) creeps up from the correct 30 kPa (for my B5423T3 turbo -see chart for your engine)
The threads are a peculiar M6x 0.80 - a standard M6 1.00mm thread will not fit
I found my locknut was also too loose for a 10mm wrench and too big for a 9mm, no doubt from sitting on top of hot turbo for 17 years. A vice grip freed it up, with another vice grip firmly stopping the rod from turning.
Make sure you don't let the rod turn AT ALL or else you will ruin the WGA.
I lubed both pieces with no-seize (grease, graphite mix from Permatex)
I found my actuator needed two turns to fit cleanly onto the turbo pin when closed. My split pin stuck rusted into the pin hole, so I wired it with copper wire until I have time to clean out the hole with a punch or drill.
Replace the screws (M8) onto the turbo cover if they are funky unless you like to hear the wish-wish-wish of the turbo dumping...
Motivation - I lost my daily race to the stop light to BMW boy this week. I found my WGA was unhooked so I was left with no boost and second place.
On Monday, the natural order of things will be restored:
Volvo First
BMW - First Loser
1997%20850%20T5%20Wastegate%20adjustment%20procedure.pdf
(163.03 KiB) Downloaded 611 times
IPD tool in place, pressure from front tire
Hose to WGA in pretty blue
Adjusted, lubed and wired (see text)
bugs11
Year and Model: 850 1996
Post by bugs11 »
Can this adjustment be made with the turbocharger out of the car?
As I understand the instructions the answer is yes, but then I'm not a mechanic so I have some difficulty interpreting straight forward mechanic documentation.
I think so. The space relationship between the WGA and the WG should not change if the turbo is removed.
bugs11
Post by bugs11 »
I put pressure to the WG nipple, at 4 psi the actuator started to move, at around 10 psi it was fully open. I assuming this is a good thing.
tryingbe
Year and Model: None
Been thanked: 26 times
Post by tryingbe »
I would buy a cotter pin and install that instead.
85 GLH, 367 whp
00 Insight, 72 mpg
There is a piece of cotter pin stuck in the WG pin hole I have to clear first, it's tough getting a punch or. Drill down there.
mecheng
Has thanked: 15 times
Been thanked: 21 times
Post by mecheng »
How many turns did you do?
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
Two turns to restore to factory setting. That is four half turns.
I believe with ME7 and HPT it starts getting dangerous to overboost. As long as I can keep BMW slush boy in his place I'm good
mecheng
Post by mecheng »
I have 2 turns as well, definitely reduced the serious lag it had. Peak boost is 12 psi. I think all HPT need 2 turns
Well, been on travel a bit, but back to regular commute this am.
BMW boy showed up faithfully for a race and I mashed the boost and he dropped off faster than Wily Coyote in a Road Runner cartoon..I then signalled and pulled into his lane to rub his little blue and white propeller in the dirt...
Order is restored...let's Volvo...
