1999 Volvo s70 Random Shut Offs
dcmatos
Year and Model: s70 1999
Re: 1999 Volvo s70 Random Shut Offs
Post by dcmatos »
obayha wrote:Go to Auto Zone in your area. Not to sure about Advance Auto as far as reading codes. I use Auto Zone here in Salisbury. They read and give me a print out of the codes. You can check fuel pressure and that should tell you a little about the pump.
Shane
It seems i'm getting the following codes
p0171
p0174
p0440
Has thanked: 1505 times
Been thanked: 3818 times
Nothing to do with your pseudo random shutoffs.
More likely your battery cables are bad and when you fussed with the new battery they gave up the ghost.
Your radio gives you a couple of tries to put the code oin then goes to OFF for two hours.
