1999 S70 T5 - ETM interchangeable with one from a GLT
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
As the title question:
I have a 1999 T5, can I replace the ETM with one from a turbo GLT? (HPT->LPT)
Or is that no good?
BMW 540i 2002
S70 Base 2000
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
Probably
Turbo to turbo yes
kallekula
Post by kallekula »
Precopster?
BMW 540i 2002
S70 Base 2000
kallekula
Post by kallekula »
Mike!
BMW 540i 2002
S70 Base 2000
Has thanked: 1613 times
Been thanked: 4075 times
Please insert 10 AUS into the slot in your computer...
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Vida/Dice will tell you. If you've plugged the replacement into the donor loom press Update Configuration when entering the Diagnostics section. In Communication- Network see the 2 x software part numbers after highlighting the ETM icon.
Of course if you don't have Vida you might get lucky anyway.
kallekula
Post by kallekula »
precopster wrote:Vida/Dice will tell you. If you've plugged the replacement into the donor loom press Update Configuration when entering the Diagnostics section. In Communication- Network see the 2 x software part numbers after highlighting the ETM icon.
So the numbers should match huh?
Doesnt seem so with the ETM I just put in. Car seems to drive fine though and it passes the etm test with a deviation of 1.3 degrees.
Is there anyway to tell from the sw nr if it is LPT or HPT?
BMW 540i 2002
S70 Base 2000
RigsPGT
Year and Model: Red 99 S70 T5,
Post by RigsPGT »
I've replaced mine with a yellow sticker which I bought it off Ebay and have the same part numbers and the car runs fine. I too couldn't find any info as to what model and year it came from. I was just happy to work and on top of that the unit was rebuilt last year :)
99 S70 T5, The Red Devil
Ported 19T and R manifold, 3" DP with Magnaflow race cat, 2.5" cat back, Precision FMIC, Rigs intake pipe, H&Rs, Bilsteins, 302's with Akebonos, Jewels, HIDs, egg crate grille, transmission cooler.
doublebug
Year and Model: XC90 2007 D5
Been thanked: 7 times
Post by doublebug »
kallekula, that number says that you have latest sw version.
So if donor car is turbo and had also updated sw it will fit if from same MY or CAN config is the same.
If you have questions about Volvo firmware ask me. I may know an answer :)
doublebug
Post by doublebug »
If ETM has yellow sticker and was manufactured after 2006 year it will have 100% latest sw.
