1997 850 glt Serious Engine Smoking Upon Deceleration
1ezliving4ume
- Year and Model: 850 glt turbo 1997
1ezliving4ume
1ezliving4ume
Ok, I've determined that the mickey mouse hole is nothing, if I'm wrong please someone say so.
- shiloh51933
- Year and Model: 04 XC70/'98 V70XC
- Has thanked: 28 times
- Been thanked: 17 times
First off thanks for your response and confirmation that the factory rods/everything should be okay w/factory T5 tune. As far as the AWD I should be good right?erikv11 wrote:For your 98 you can just get white injectors, a 15g or A 16t, and a 98 T5 ECU. Easy drop it in and away you go, zero issues for the rods and internals as long as you keep the standard T5 tune.
You will want to pay attention to emissions differences between the two cars to avoid a CEL.
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
Sommerfeldt
- Year and Model: 2018 S90 T8
- Has thanked: 55 times
- Been thanked: 42 times
You're right - nothing goes there, at least not since the '94 models. And even then, I've never seen anything there.1ezliving4ume wrote:Ok, I've determined that the mickey mouse hole is nothing, if I'm wrong please someone say so.
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
- Been thanked: 4071 times
Don't worry about an o-ring in an oil pan. I left a flashlight in an oil pan once. Found it three years later. I swear it added the power of 2 D cells to the engine.
1ezliving4ume
Your a funny man! but I feel I should at least try to get it out and I will. On a good note my turbo is ready for pick up from the re-balance shop so I should beable to get alot done in the coming days.
One thing I am still trying to find is the banjo bolt washers for the oil and cooling line that go to the turbo.
If all of this works out I may end up keeping this car and start to mod. it a little it seems like there are numerous mod.'s I can do. I tell you some days I wonder if I will ever get this thing back together. I suppose that's a pretty common thought when your in the dog days of the project. Not disassembling or really assembling, just gathering parts and information.
I did manage to install the exhaust manifold to the head and the t-stat housing to the head last night. so that's a little forward progress.
- shiloh51933
I can't wait to see the posted pics of finished project, I've been keeping an eye on this thread and I know the finished product is going to work out nicely!!1ezliving4ume wrote:Your a funny man! but I feel I should at least try to get it out and I will. On a good note my turbo is ready for pick up from the re-balance shop so I should beable to get alot done in the coming days.
1ezliving4ume
So, I got my turbo back from the balancing shop. They recommend opening up the Compressor Bypass Valve. Glad I did, it was toast. the rubber was sucked in. Now I have to figure out if I want to rebuild it or go with a different style. I wish the reviews were better for the IPD blank off plate and remote Compressor Bypass Valve. I'll probably just get the heavy duty one on IPD's web page.
http://www.ipdusa.com/products/4898/114 ... pass-valve
Will this work with the blue spring or is it a waste of money
- shiloh51933
Why don't you just clean it up, replace whatever is necessary and see what happens since it's cheap enough/easy enough to just go back to swap it out if your not happy w/rebuilt CBV.1ezliving4ume wrote:So, I got my turbo back from the balancing shop. They recommend opening up the Compressor Bypass Valve. Glad I did, it was toast. the rubber was sucked in. Now I have to figure out if I want to rebuild it or go with a different style. I wish the reviews were better for the IPD blank off plate and remote Compressor Bypass Valve. I'll probably just get the heavy duty one on IPD's web page.
- 11 Replies
- 2270 Views
Last post by wizechatmgr
- 1025 Views
Last post by mika
- 711 Views
Last post by erikv11
- 41 Replies
- 6730 Views
Last post by Seaway
- 1142 Views
Last post by vtl
