2004 Turbo or 2002 non-Turbo V70, your choice?
waffleshill
- Year and Model: 2004 V70R, 2006 XC70
If it's a AW55 car you're probably in for a transmission soon... There's a reason they're ultra cheap.
2004 V70R Mystic Silver Metallic/Nordkap M66 287,000 miles
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
waffleshill wrote:If it's a AW55 car you're probably in for a transmission soon... There's a reason they're ultra cheap.
Hopefully he got one that had it already rebuild
Yep. I had an '04 Nissan Maxima which I beleive had the AW55 and it was a rock with no issues ever. Obviously hoping for the same. The Volvo shifts SO smoothly and seemlessly, I can't forsee it breaking soon. Is there an easy way to tell if the transmission has had the valve body replaced? Carfax doesn't list it.waffleshill wrote:If it's a AW55 car you're probably in for a transmission soon... There's a reason they're ultra cheap.
What does an Indy shop charge for valve body rebuild on the AW55?
The "gold" one was not the gorgeous gold you're referring to. It was the champagne gold as seen on every mom's minivan and Camry. I would have bought Maya in a heartbeat for a premium!oragex wrote:...Gold - I believe it's called Maya - is surely .. apart, but now thinking I would have loved one.....
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
01-02 Volvo, shifts smoothly -> VB was addressedVolvo2112 wrote:The Volvo shifts SO smoothly and seemlessly, I can't forsee it breaking soon. Is there an easy way to tell if the transmission has had the valve body replaced? Carfax doesn't list it.
Depends on what exactly has to be done, plus labor rate. Mine was replaced for $1250, ~$700 was for a fully rebuilt VB (with Sonnax kit). If you go for refurbished solenoids alone, it will be cheaper.Volvo2112 wrote:What does an Indy shop charge for valve body rebuild on the AW55?
- 1264 Views
Last post by DEWFPO
- 887 Views
Last post by Rocambolesque
- 10 Replies
- 2349 Views
- 1300 Views
Last post by wizechatmgr
- 1323 Views
Last post by kallekula
