Hi!
So I recently purchased this 96 R with 190.000 mls on it where the PO claims the ATF had been changed within the last 10 years.
SInce it doesn´t shift supoer smooth (not bad, just not perfect) I´d like to change the ATF. Since in Europe ATF istn´t exactly cheap I would either
- do a drain and refill (3x) with Volfo ATF Dex 3 for 150$ or
- try to pump Mobil 1 synth ATF through the system by disconnecting the tranny fluid line from the radiator/cooler for free. ( I found the Mobil 1 synth ATF in my backyard - it had been stored outside in a factory sealed 6 gallon plastic container ever since I got it back when working for ExxonMobil in 2002 or 2003)
What would YOU do given both options?
Thanks, Clemens
96 850 R Mobil 1 synth ATF or Volvo Dex 3
- Has thanked: 1614 times
- Been thanked: 4078 times
If you change the title to Volvo DEX 3 vs 13-year-old Mobil 1 I think the responses will be clear
- Clemens
- Has thanked: 501 times
- Been thanked: 228 times
You're probably right. Might be the wrong place to save.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
JRL
- Year and Model: Several
- Been thanked: 16 times
Dex
NEVER use 10 year old transmission fluid, it's probably junk by now
mecheng
- Has thanked: 15 times
- Been thanked: 21 times
If you are concerned with cost change fluid once. I didn't notice much of a difference beyond the 2nd change but I did with the first. Unless the fluid is totally cooked (smells burnt) one fluid change is good especially if you use a decent quality brand. Clean drain plug from metal filings
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
- RussB
- Year and Model: '00 S70, '04 S60
- Has thanked: 3 times
I would buy 12 qts of inexpensive transmission fluid, Store brand (like NAPA in the US, I don't know what you have in Austria) is fine. Drain the sump, then let the tranny pump out the old oil, and add 2 qts until you've used up all 12 qts.
I've done that yearly for 13 years in my 850...it will have the smoothest shifting tranny in the junkyard!
ThommyKent
- Year and Model: 91 245 97 850 T5
- Been thanked: 5 times
Use the Mobil 1 from your backyard, its fine.
- Has thanked: 312 times
- Been thanked: 818 times
Some fodder, this chemist from Mobil says 20 year old Mobil 1 checks out just fine: http://www.bobistheoilguy.com/forums/ub ... ost2539939
The chemist in me says the oil is fine. I would still throw it out and start fresh.
- RussB
There are many cars running 10+ year old factory tranny fluid.
Not a problem to use fresh, old fluid
