00 Volvo V70R AWD Humming/whirring
Daiffi
Year and Model: V70R AWD -00
Post by Daiffi »
Hey all ! I have tried to search the problem from other volvo forums but it seems here is more volvo experts. :)
I have this weird humming/whirring noise in my volvo now. I start the car the noise begins and wont stop until i shut down engine. It doesent matter am i driving or in park. And when i shut down the engine noise continues 1-2 seconds and you clearly can hear something shuts down. Car has Ardic but i dont know does that anything. I link video from youtube wich i have recorded. You cant hear the sound clearly when in engine, but when i start roaming around car you can hear the high pitch noise outside. To inside that sound goes more like humming or " Huuuuuu"
https://www.youtube.com/watch?v=L-D_uYa ... e=youtu.be
Explanation can be little messy but i cant do better for english. :oops:
waffleshill
Year and Model: 2004 V70R, 2006 XC70
Post by waffleshill »
Fuel pump? CCM fan? ECU fan?
2004 V70R Mystic Silver Metallic/Nordkap M66 287,000 miles
cuhfs
Year and Model: 850,XC70,XC90,S60,80
Has thanked: 17 times
Been thanked: 31 times
Post by cuhfs »
Alternator bearing? Here is what I would do... I recommend a Mechanics-Stethoscope here's the sponsor link from this MVS where I put in Mechanics-stethoscope https://www.amazon.com/s/ref=nb_sb_noss? ... tethoscope
It may help you find the noise.
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
04 XC70 Auto (gone)
04 C70 Convert (gone)
clifford06
Year and Model: 2000 T5
Has thanked: 6 times
Been thanked: 4 times
Post by clifford06 »
Greetings. Check water pump. Could be bad bearing.
Veilleuxpbd
Year and Model: s70 2000
Post by Veilleuxpbd »
Sounds like a fuel pump, if you remove the cargo liner, youll see a black plastic piece covering some metal (where you would access said pump) along the base of the back of the seats (whre they fold). Listen there, if the sound is coming from there, its the pump, it the sound comes from the engine compartment, its likely a bearing, but since it keeps on spinning 1-2 seconds after you shut down the engine, i'd put my money there, so to speak :P
Daiffi
Post by Daiffi »
Veilleuxpbd wrote:Sounds like a fuel pump, if you remove the cargo liner, youll see a black plastic piece covering some metal (where you would access said pump) along the base of the back of the seats (whre they fold). Listen there, if the sound is coming from there, its the pump, it the sound comes from the engine compartment, its likely a bearing, but since it keeps on spinning 1-2 seconds after you shut down the engine, i'd put my money there, so to speak :P
Yeah i also think strongly its fuel pump. You can hear it very loudly when you put ear to passenger side back wheel. And thanks for the instructions ! :)
Has thanked: 2200 times
Been thanked: 1852 times
How full is your fuel tank? The pumps get noisy as they get older, but don't like to be sitting in a low fuel level tank as they run hotter in this scenario. If you fill you tank, is it as noisy?
