As some already know, my car is stopped with the immobilizer activated, does not recognize the ECM module.
After much researching, I found the network CAN HIGH on volvo VIDA by measuring the resistance on the connector odb2, the network should have resistance 55-60 ohms and mine is with 120ohms, it indicates that I have open circuit on the CAN network
My next step should be to check the can network wires through the wiring diagram and test the continuity of all the network wires or would have some way to identify more easily where this network "open circuit".
Thank you
2009 C30 - Can bus with 120ohms
- 4661 Views
Last post by ChrisatXeMODeX
- 1517 Views
Last post by drjurman
- 38 Replies
- 22442 Views
Last post by Rtea
- 3551 Views
Last post by oragex
- 13939 Views
Last post by 93Regina
