I have a quick question to ask.
Just got the cheap PCV kit from IPDUSA. Part number 124569
It came with
5 black O-rings
4 washers with black plastic on inner edge
1 green O-ring
What are these for? Where do they go?
Should I use some kind of adhesive with the gasket?
Any idea?
I am trying to work on the car starting this evening.
Thanks,
99 V70XC PCV quick question
PatternFlyer
- Year and Model: 99 V70 XC
- Has thanked: 6 times
- Been thanked: 7 times
- fullsize_26201.jpg (76.09 KiB) Viewed 1319 times
Clockboy
- Year and Model: 05 xc70, v70 2.5t 06
- Has thanked: 2 times
I just did the 98 version and the hose is completely different. My guess is:
green washer - dipstick
4 washers - for banjo bolts
5 orings - fuel injectors.
My guess is you'll recognize them and figure out how they go as you disassemble.
PatternFlyer
dipstick? engine oil dip stick?'
- Has thanked: 1611 times
- Been thanked: 4072 times
No adhesive on the intake manifold gasket
The metal can connector from the oil trap to the block may be different than the one on your car. I put mine rubber side against the oil trap, some did it the other way. My way is faster.
Getting the banjo bolt under the manifold aligned and in is tough work.
- Year and Model: Many Volvos
- Been thanked: 76 times
That may be the biggest understatement I have read in a while.abscate wrote:Getting the banjo bolt under the manifold aligned and in is tough work.
Ozark Lee wrote:That may be the biggest understatement I have read in a while.abscate wrote:Getting the banjo bolt under the manifold aligned and in is tough work.![]()
If I did this job again on a 1999 I think I would pull the alternator to get better access
PatternFlyer
So farn i pulled the entire fan assembly after getting the tube that hooked up to the ETM.
got the air box out, but the tube netweek the turbo & airbox has a few hoses that are hard to take out.
does vadis show entire process including the long hose assembly from the front to the back?
not easy even after I did the PCV a few years ago. Can't remember how I did.
98 actually are not the same as 99. Vadis shows 99 as 98, so i am looking at it as 2000.
turbo control valve hoses will be replaces also.
hope I can finish today.
- 18 Replies
- 3013 Views
Last post by Clemens
- 869 Views
Last post by DrJammer
- 485 Views
Last post by hausmeister
- 9 Replies
- 1597 Views
Last post by bmdubya1198
- 622 Views
Last post by ggleavitt
