I only gave the wastegate adjustment one full turn and I'm amazed at how much more responsive the car is when accelerating or flooring it to pass. It's like a different car: feels like another 40-50hp. (I can't imagine what two turns would do!)
So my question is, can these old engines handle the extra power, or is it really the same power just appearing earlier in the curve? (Meaning, are the internal stresses on the engine about the same as normal, it just gets to the normal max 'stress' faster?) I love having the extra power there if I need it, though I generally drive pretty laid back. I just don't want to take a year off my car's life.
I know if you go much over two full turns you get too much boost at low RPM and risk rods or other problems, but what about under 2? Should it handle it fine?
1995 850T Adjusted turbo waste gate and wow!
850TurboTurtle
- Year and Model: 96 850T, 05 S80T6
- Has thanked: 10 times
- Been thanked: 5 times
j-dawg
- Year and Model: 1999 V70 T5
- Been thanked: 33 times
Grab a Mityvac and find out how many PSI you're opening the wastegate at. It's possible that you've set it correctly, and you're just back up to factory spec, in which case there's nothing to worry about.
- Has thanked: 1502 times
- Been thanked: 3817 times
There aren't shortcuts adjusting this stuff other than following the factory settings, which require the precision pressure gauge and time. The mantra here is the 2 full turns past stock are ok on a -1998 but much less on 1999+
mecheng
- Has thanked: 15 times
- Been thanked: 21 times
Like the others stated, don't go more than two turns in general. And yes you are correct, it shouldn't affect the peak boost, it will just reduce the lag. In my 98 T5, it still has lag, but it is more bearable with 1 turn.
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
- Clemens
- Has thanked: 473 times
- Been thanked: 219 times
So, will moving the boost curve to the left (boost kicks in earlier) increase the torque? HP ratings won´t really be effected, at least not peak hp, I believe.
Just curious cuz the AT equipped turbos have reduced torque and hp (at least on the 96 and 97 R) so I wonder if that could cause an increase of torque into an unsafe range (for the AT, not the driver).
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
Donor: 1995 854 10V
mecheng
I've read people safely putting 300hp on the stock 4 speed trans without any issues. It is a very well built transmission, fluid change every 50,000km and it should not cause any issues.Clemens wrote:So, will moving the boost curve to the left (boost kicks in earlier) increase the torque? HP ratings won´t really be effected, at least not peak hp, I believe.
- Clemens
300 hp with an AT? Interesting... I read somewhere that on the 96 and 97 R the hp was reduced to 240 and limited to 300 Nm (Motronic 4.3 as in the T-5R) in the AT models opposed to 250hp and 330 Nm (Motronic 4.4) in the MT models (not available in the US) in order not to exceed the max torque and hp for the Aisin Warner. But maybe the idea was to stretch the max torque band wider by reducing max hp because that is more useful with the 4-speed AT.
Summer: 1996 855 R
Donor: 1995 854 10V
Donor: 1995 854 10V
- Has thanked: 2652 times
- Been thanked: 1245 times
A guy around here has been over 300hp in his '95 or '96 850 R for several years.
