1995 855 Negative battery cable corrosion
lcc014
Year and Model: 855, 1995
Has thanked: 2 times
Been thanked: 11 times
Post by lcc014 »
Recently, I noticed that negative battery cable had white color powder. I brushed it off with metal brush and cleaned negative battery terminal with battery cleaning tool. 1 day later, the white color powder appeared on the battery cable again. It looked like corrosion to me. This has never happened before in last 20 years. My battery was purchased from dealer back in 2008. There is no fluid around the negative battery terminal.
Is the battery leaking acid and cause corrosion on battery cable ? Is it time to get a new battery ?
Thanks.
Ching-Ho Cheng
tryingbe
Year and Model: None
Been thanked: 26 times
Post by tryingbe »
85 GLH, 367 whp
00 Insight, 72 mpg
Been thanked: 4065 times
Salty sea air and old copper. It's not battery acid, it's just entropy.
7 years on a New England battery...well done !
lcc014
Post by lcc014 »
Thank you for the response. I am thinking of battery replacement as winter is coming ....
Has thanked: 311 times
Been thanked: 817 times
It's almost certainly battery acid and the battery is almost certainly the problem. You can either seal around the post with something like dielectric grease and a battery pad, see if that slows it down, or get a new battery. I agree 7 years is pretty good life out of a battery.
It is possible that the battery is leaking because of overcharging, so keep an eye on the charging system. You don't want to kill a new $100 battery.
delete
lcc014
Post by lcc014 »
I will check the battery voltages: car on and car off to make sure that charging system does not put out more than 14V to charge the battery.
Thanks.
