Engine Compartment Fusebox
The fuse itself should be OK in your case (otherwise the ECM and a ton of other branches would lose power)
Sorry, cross the ECM out (I was looking at the Diesel arrangement)
The HO2S heater circuits will be affected on your car.
Yes, I would definitely check it
2000 s70 n/a no spark
- regent
- Year and Model: 2015 XC60 T5
- Has thanked: 2 times
- Been thanked: 12 times
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired
1987 340 DL - retired
2015 BMW 335i
Veilleuxpbd
- Year and Model: s70 2000
But in the engine compartment no fuse is marked as 11b/4, only numbers like 1 2 or 3.
Is it the number 4 fuse?
Also, what do you mean by 'cross the ecm out', is it not something affected by this fuse? Is it something I should consider as 'ok'?
Thank you
Thank you
I think we are getting closer here. Pin 1 should be constant 12VDC, not fluctuating, correct. The coil is fired by the ECU grounding pin 4, not by turning on pin 1Veilleuxpbd wrote:Okay, Pin 1 has intermittent 12vdc when attempting to start the car, which from what I understand means that the ECU is telling the ign coil to fire.
Pin 2 has about 5vdc on it when ign is on.
Pin 3 and 4 are dead.
Does this mean that the ECU is good, but that the supply wire for the primary winding in the coils is gone?
( my understanding and consistent with wiring diagram in thread)
Are all those mounting bolts tight?
( deleted bad information)
Thanks mike, corrected my mistake above
Veilleuxpbd
Well.. two good news and a bad one.
First good; the car runs!
Second good; you guys are awesome, and I want to thank everyone who's helped me
Bad one; I am an idiot
I had checked the fuses when the car got towed home, and every fuse was ok, but since then I worked on the car and attempted to start it (and jump it) a number of times. Fuse 11b/4 was indeed shorted, changed the fuse, boosted the car, gave it a few cranks and smoked the whole parking garage with oil smoke
Again, I am deeply thankful for everyone that has helped, I'll be on my way to find a job
Nice.
Nothing like that feeling of those 5 cylinders springing to life after a week of troubleshooting...except hearing a 1954 36 HP VW engine last run in 1963 start up, perhaps.
- Year and Model: Many Volvos
- Been thanked: 76 times
Barn find?abscate wrote:Nice.
Barn find of two sedans and eight motors
- regent
Two is greater than one (usually)Veilleuxpbd wrote:Well.. two good news and a bad one...
Good job, glad you sorted it. Don't forget to pay yourself for the hard work!
2015 BMW 335i
2015 BMW 335i
- 1941 Views
- 3042 Views
Last post by Roger_850T
- 3301 Views
Last post by ndphotonl
- 1386 Views
Last post by Ellipsis
- 797 Views
Last post by E Showell
