2001 V70 2.4T How to remove pressure hose from steering gear
prwood
Year and Model: 2001 V70 2.4T
Has thanked: 9 times
Been thanked: 22 times
Post by prwood »
I'm trying to replace the power steering pressure hose on my car, as it's developed a leak. I've been following the directions for Pressure Hose and Return Hose downloaded from VIDA. The one thing I can't figure out is how to loosen the nipple that attaches the hose to the steering gear. The wrench I'm using is one from this flare nut set:
http://www.harborfreight.com/5-pc-metri ... 68866.html
It worked well enough to loosen the nipple on the other end of the hose at the power steering pump. On the end at the steering gear, I can get the wrench around the nipple, but I cannot move the wrench in order to loosen it. Is there a special wrench or other tool that can move in that small space, or is there a way to make more space up in there?
Cars I've owned:
cuhfs
Year and Model: 850,XC70,XC90,S60,80
Has thanked: 17 times
Been thanked: 31 times
Post by cuhfs »
Not exactly sure which or where that particular nut is... but when I did my steering rack, I found a flared crows foot wrench http://www.harborfreight.com/7-pc-38-in ... 68999.html was needed and could only do about 1/8 turn or less at a time. Good luck
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
04 XC70 Auto (gone)
04 C70 Convert (gone)
prwood
Post by prwood »
cuhfs wrote:Not exactly sure which or where that particular nut is... but when I did my steering rack, I found a flared crows foot wrench http://www.harborfreight.com/7-pc-38-in ... 68999.html was needed and could only do about 1/8 turn or less at a time. Good luck
Thanks! That looks like it will work really well. I have a few extension bars I can attach them to and hopefully that will be able to get in there. The attached photo shows the diagram I'm using with the parts in question circled in red.
As a side note, I actually didn't realize my first time through that the shaded piece in the diagram is a special tool you're supposed to use (the equivalent of the crow's foot wrench). I assumed it was a pipe and that they were highlighting the one you were supposed to remove. :-) I had been talking to my wife about the crow's foot wrenches you recommended, and then I showed her the diagram, and that's when she pointed out that the tool in the diagram looked like the wrenches I had just showed her. *facepalm* That explained a lot, like why the diagram had three pipes when the car only actually had two, or why the shaded "pipe" in the diagram didn't have a nut at the end of it...
In any case, I think if I get those crow's foot wrenches I'll be able to properly complete the replacement. I'll let you know how it goes!
Screen Shot 2015-10-04 at 8.10.50 AM.png (194.14 KiB) Viewed 1289 times
Cars I've owned:
VolvoChef
Year and Model: v70 1998
Post by VolvoChef »
Hey, I have a question for you: did you lower the sub-frame at all because I'm having the same problem as you. even with a crowsfoot wrench on an extension it's damn near impossible to tighten the nut.
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
When I did steering hose replacement on 2001 V70 T5 a few years ago, I did not drop the subframe. It was difficult job to get to everything and I don't remember the tools I used. However, I do not have metric crows foot wrenches, so I am sure I did not use them. I did get everything tight and did not have leaks.
