1995 850 GLT Transmission Fluid Service
Can anyone tell me if it is safe to go ahead and replace the automatic transmission fluid in my '95 850? The car is now pushing 300,000 miles (nothing out of the ordinary for a Volvo), with the original transmission fluid still in the car. I know the owner's manual doesn't call for any tampering with the transmission fluid (which I attribute to giving 300,000 miles of driving with the original transmission), but after 20 years and that amount of driving the transmission fluid has to wear out at some point. The fluid is of a brown hue; new fluid should be red. My question is: is it safe to replace the transmission fluid, or is the current transmission fluid "holding it together," so to speak? Thanks for any clarification!
- Year and Model: Many Volvos
- Been thanked: 76 times
You can (and should) change it but do it as a series of drain and fills rather than as a flush.
Given that you have 300k on it I think I would stick with a standard Dexron rather than a synthetic and I would avoid Dexron VI. All Dexron is supposed to be backwards compatible but Chevy has specifically said to not use Dex VI in the transfer case on the older trucks which tells me that it is not totally backwards compatible. Dex IV would be what I would look for if I were you. The car shipped with Dex III but that isn't licensed anymore so there is really no such thing.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
I don't know....opinions are divided on this.Volvo doesn't recommend changing fluid in automatic transmissions if there wasn't some kind of intervention on transmission.That's in owner manual and that is official.
I'm around 300k+km,bought the car almost brand new and i had never replaced fluid in my auto transmission.Shifts like a 1st day i bought it.
Original/factory auto transmission fluid is not red like replacement fluid is.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Lee,Ozark Lee wrote:You can (and should) change it but do it as a series of drain and fills rather than as a flush.
Thank you very much for the response. I will stick with Dex III. Just a few questions: If the transmission fluid can/should be changed, why does the owner's manual call for no servicing of the fluid? Is the old fluid actually keeping the transmission going longer? When you are talking about a series of drains rather than one big flush, how much should come out, and how frequently? What is the reason for this, and what does it do for the transmission that a big flush wouldn't do? Thank you very much for your response.
Thank you for that clarification... I did not know factory fluid was a different colour. As far as shifting in my car is concerned, the transmission is still strong, but 1st to 2nd can jolt you around a little bit. I don't know why the owner's manual would call for no replacement, though, as all lubricants eventually lose their lubricity, which is problematic.misha wrote:I don't know....opinions are divided on this.Volvo doesn't recommend changing fluid in automatic transmissions if there wasn't some kind of intervention on transmission.That's in owner manual and that is official.
combatkarl
- Year and Model: 1997 850 GLT
Drain and Fills consist of draining the fluid from the automatic transmission by removing the drain bolt. Approximately 3 quarts of fluid will drain. Fill with the amount that is drained out. Then drive the vehicle awhile before performing another drain and fill. Some suggest driving 500-1000 miles before performing another drain and fill. The drain and fill procedure could be repeated 3-4 times, if desired. Here's a tutorial from the site (there are likely others, but this is the first I found) https://www.matthewsvolvosite.com/forums ... =9&t=26863
And a discussion about Drain and Fills Vs ATF Flushes - Atf flush vs drain and fill and frequency
Karl
1997 Volvo 850 GLT
2001 Honda Odyssey
1999 Mazda Miata
2012 Dodge Journey
1984 Honda Nighthawk S bike
1997 Volvo 850 GLT
2001 Honda Odyssey
1999 Mazda Miata
2012 Dodge Journey
Thank you very much! In other words, remove the drain bolt and just let it go until it stops? Doing that will only let out approx. 3 quarts? What's stopping the whole transmission fluid from draining through the drain bolt?
- Has thanked: 312 times
- Been thanked: 818 times
Correct, just pull the drain plug and about 3.5 quarts will drain out. You don't need to wait until it stops, that may take a very long time because it continues to seek, just wait until it slows way down.
Measure how much you drain and put exactly that much back in, this step is key. If you try to blindly fill until the trans fluid hits the right spot on the stick then you end up doing a lot of guessing and it can be tough to get it right.
- misha
Transmission fluid can't be contaminated like engine oil since it's closed system.kw1999 wrote: I don't know why the owner's manual would call for no replacement, though, as all lubricants eventually lose their lubricity, which is problematic.
Official Volvo statement is that auto transmission fluid is good for the life of the car and they DO NOT recommend replacement,IF there was no intervention of any kind to transmission.That said....IF system is never opened or contaminated,there is no need for fluid change.
Volvo does not recommend for timing belt parts to be changed every 2nd replacement if they are good,but owners replace them anyway as a safety precaution.
Transmission oil can only be contaminated IF chamber for transmission fluid in radiator blows and contaminate it with coolant.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 723 Views
Last post by tryingbe
- 602 Views
Last post by kw1999
- 1964 Views
Last post by mf70
- 10 Replies
- 2097 Views
Last post by MrGruffles
- 1975 Views
Last post by psamanni
