1995 850 GLT Transmission Fluid Service
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
kw1999 wrote:If the transmission fluid can/should be changed, why does the owner's manual call for no servicing of the fluid?
Because they don't want you messing with it while it is under warranty. If they were so confident that the fluid is good forever, why don't they put a lifetime warranty on the trans?
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
When it's under warranty you CAN'T mess with anything on the car or you loose warranty. :wink:
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Has thanked: 311 times
Been thanked: 817 times
kw1999 wrote:Thank you very much for all of that information. No need for a filter change?
There is no filter to change! Just drain and fill. The drain plug is magnetic there will be a thin layer of metal sludge on it; wipe it off.
kw1999
Year and Model: 850 GLT, 1995
Post by kw1999 »
Thanks for all the info, everyone! You have been most helpful and informative.
