1999 V70 T5 clunking noise front driver's side when coasting
Clockboy
- Year and Model: 05 xc70, v70 2.5t 06
- Has thanked: 2 times
When I replaced my left front axle I had finished up and took it to the library parking lot to see how it was. I was doing figure eights and all was fine until a clunking/vibration started to happen. Drove it back to the house fighting a vibration over 20 mph and cursing myself for doing an aftermarket axle. Went to take the wheel off and realized the bolts were loose. I then remembered that when I was going to torque the bolts my neighbor came to bs. Even had the torque wrench in my hand while we talked. i have that same t-shirt.
- Been thanked: 504 times
While waiting for the bolts, if you need the car to go to work, it is relatively safe to drive with 4 bolts, I see quite a few cars in my area (not Volvo) with only 4 bolts and seem to run fine.
Just avoid high speed etc.
These bolts are on ebay, junk yard for cheap.
Or local dealer.
Or local dealer.
- Been thanked: 4063 times
My classic is doing front end work, cracking the bolts, Jack and stand, but then working on side one and forgetting about side two.
Since then, I make the protocol crack bolt, Jack stand, remove tire. That way you don't get another Tshirt. After I finish one side of brakes, the tire stays off until I'm ready to Jill, then tires on, bolts on hand thread, lower and torque to spec
- 665 Views
Last post by oragex
- 881 Views
Last post by vtl
- 1177 Views
Last post by whatgoeson
- 305 Views
Last post by chitownV
- 958 Views
Last post by Cees Klumper
