98 V70 trunk open dash light
Bren
Year and Model: 1998 V70R
Post by Bren »
Even though my trunk is closed the light stays on all the time.
Is this common or an easy fix? If not, is there a way to disable the light?
Garage:
1998 V70R
2006 XC90 2.5T - Family Hauler
1993 Audi S4 (Sold)
2001 VW Jetta 1.8T (Sold)
1988 Mazda 323 GTX (Sold in pieces)
Ben850
Been thanked: 7 times
Post by Ben850 »
Bren wrote:Even though my trunk is closed the light stays on all the time.
I have not started work on my '98 V70 XC, but it does the same thing although the hatch is secure.
It looks like it will have to wait until spring again.
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
kahl
Year and Model: 2000V70XC
Been thanked: 10 times
Post by kahl »
Are there other items on your tailgate not working such a license plate lamps, wiper,electric lock?
Bren
Post by Bren »
kahl wrote:Are there other items on your tailgate not working such a license plate lamps, wiper,electric lock?
Everything else works.
Garage:
1998 V70R
1993 Audi S4 (Sold)
DrJammer
Year and Model: 2000 V70XC - 195k
Post by DrJammer »
I have this issue on my 2000 V70 XC, and it annoys the heck out of me since I will never have a dash clear of warning lamps. I suppose I could get around to removing that bulb or the black tape trick, but I digress.....
There is a common problem with wires getting pinched, etc. in the tailgate hinge. There are many posts about pinched wires in the gate hinge. I have taken my rear pillar apart about 3x looking for the faulty location that allows this dash light to read that my tailgate is still open.
I have given up, I know the trunk is shut, so no big deal. As you said though, make sure you disable the light, on the 2000, there is a dial that dims and turns off, so I just leave my trunk light off, unless I need it. Just remember to leave it off, and make sure you have jumper cables on you at all times. If you can't turn the light off manually in a '98, I would remove the bulb.
Also, be sure to let your mechanic know about this issue if/when you take the car into shop. My crew was replacing my fuel pump and the light remaining on was killing the battery quick and they basically ripped my tailgate panel apart to try and remedy, and this was right after I replaced my panel clips....
Ex-Volvos
2004 v70 N/A - traded in at 75k
2008 S60 - leased
1998 S70 T5 - might still have her if I knew about this forum when I owned it
Gliderman vt
Year and Model: '99 V70 XC
Post by Gliderman vt »
What is involved with a proper and permanent fix to this problem?
Tim
kahl
Post by kahl »
The wires going into the tailgate need to be repaired.
FlyingVolvo
Has thanked: 51 times
Been thanked: 74 times
Post by FlyingVolvo »
The wires can be a culprit, but often it will affect more than just one item. In my case (2000 V70XC) I had to replace the tailgate latch/lock to get it to go away. At first I felt dumb for spending so much to get rid of a light (I had resorted to electrical tape over the light...), but then I realized that 15 years of had really taken a toll on it. I've always had to slam the thing very firmly to get it to lock. Now it closes with so much ease!
2000 V70XC - 340,000 miles
2023 V60 T8 PE
benpineapple
Year and Model: '06 V50 T5, '13 XC90
Has thanked: 5 times
Been thanked: 4 times
Post by benpineapple »
Could be the tailgate latch/lock assembly. In the doors, the door ajar switch is built into the lock assembly, I'm pretty sure it's the same case with the tailgate.
Could also be that your tailgate isn't closing all the way. The tailgate catch should have a piece of thick black plastic around the outermost (towards rear of car) catch post. If the plastic there is mangled, or gone entirely, replace it. I used electrical tape, wrapping the catch thoroughly. Tailgate light immediately started closing properly, and without having to slam it.
Hope that helps. Ps.I did the fix last fall, and it's still holding up just fine.
2006 V50 T5 [190,xxxM]
2013 XC90 FWD [80,xxxM]
2001 V70 X/C AWD [sold at 120xxxM],1998 V70 AWD [RIP at 249,255M], 1990 240 [SOLD at 220xxxM]
Bren
Post by Bren »
benpineapple wrote:Could be the tailgate latch/lock assembly. In the doors, the door ajar switch is built into the lock assembly, I'm pretty sure it's the same case with the tailgate.
Do you have a pic?! This would really help. I'd love to see what you mean
Garage:
1998 V70R
1993 Audi S4 (Sold)
