Hi, I hope someone has some good advice. 1994 Volvo 850 non-turbo automatic 197,000 miles. At idle the car shakes excessively so started investigating.
Car idles rough but seems fine when driving it. By unclipping injector plugs I determined cylinder No. 1 (closest to passenger side) isn't firing as there is no change when I unhook it, whereas the engine chugs severely if I unplug any of the other injectors. I have several other 850's to swap parts with. All the other cars work fine with the parts I swapped from this car.
Here's what I've done: Swapped then replaced plugs with Volvo OEM's. Swapped plug wires. Removed injectors and cleaned them, and put them back in a different order. Listened to injectors with a stethoscope and they all 'click'. Swapped distributor cap and rotor. Swapped MAF. Checked cylinder pressure - all between 180 and 185 psi. Checked fuel pressure (with a tire gauge) 40 to 45 psi. Checked codes and there weren't any. Checked all the vacuum lines and the PCV system pulls negative pressure.
If I rev the engine to 2000 rpm or so and unplug injector No.1 there is a slight difference, but if I unplug any of the other injectors there is a pronounced chugging so it seems like cylinder No. 1 is firing at least partially at higher rpm no load, but not as strong as the others. I thought about switching fuel pump but based on the fuel pressure don't think that's the problem. Gas mileage seems fairly normal.
Anyone have any thoughts? Thank you!
1994 850NA Cylinder misfire MVSOLVED bad manifold gasket
- Year and Model: Many Volvos
- Been thanked: 76 times
Perhaps a wire loom problem. Is the #1 injector trying to fire? You can just stick your finger on it and feel it pulse. Also compare the way it feels when it fires to the other injectors. The injectors should have a crisp snap sort of feel to them when they fire. If the #1 feels duller it could still be clogged.
If you get no pulse at all then it is a wiring problem. All of the injectors fire at the same time on a '94 N/A so it should be an easy fix if it is wiring.
- Has thanked: 311 times
- Been thanked: 817 times
Alas, this could be a burnt exhaust valve in cylinder #1. I suggest you check the compression.
- boerence
- Year and Model: 1996 850
Thanks for the tip Lee. So you're saying that all the injectors pulse at the same time? If that's true could I switch the wires from injectors 1 and 2, and then if it's No. 2 that doesn't fire (using the wire for No. 1) that would pinpoint the problem as being in the loom. I did inspect the wires as far as I could and saw no visual problems.
erikv11, as stated, I did a compression test and cylinder No. 1 was the same as the other four. If the exhaust valve were burnt I would assume there would be no compression on that cylinder. Correct?
1995 850 sedan
1996 850 sedan
1996 850 wagon
1996 850 wagon
2001 silverado
Black lab that's a duck huntin' maniac
1996 850 sedan
1996 850 wagon
1996 850 wagon
2001 silverado
Oops - I even went back up and scanned the OP but I just did not see the compression test mentioned. But I do now ... you are right, there is no danger of valve trouble.
The test you suggest about switching around the injector plugs is a good one, go for it.
- Been thanked: 504 times
Mark the wires at the distributor cap (photo in forum or the web).
Now INTENTIONALLY swap the #1 connector with a nearby connector.
Start engine, if the problem moves to another cylinder then the high-tension wire is bad (visual inspection can be deceptive).
At that mileage close to 200K, a new set of Bougicord is highly recommended (do NOT use another other brand).
I think you have eliminated everything except the number one fuel injector wiring loom.
You could back plane the electrical connectors to test voltage but I think I would go back trace the wires and look for breaks since you have to do this anyway to repair.
Nice troubleshooting acumen !
- boerence
Thanks everyone for your advice. Knowing all the injectors fire at the same time is very helpful. I started the car and pulled off injector plug 1 - barely perceptible change, basically no change. Then I pulled off injector plug #2 (of course engine sputtered on 3 cylinders) and plugged No. 1 onto No. 2, and that brought it right back to where it was. So I don't think there is a problem with the wiring.
Pulled off rail, tested injector with my homemade syringe pump, and it squirts just fine - also tested another one and it was just the same. So I don't think injectors are the problem.
Looked inside the manifold through the injector holes and there's something funny going on at the very left side of the manifold at cylinder No. 1 - I think the manifold might have a crack in it although I can't see any on the visible portion of the outside of it (see photo, if it attached). I need to get a bore light and get a better look at it. That might be the problem - I checked my stash of parts but no intake manifold - didn't think I would ever need one I guess.
1995 850 sedan
1996 850 sedan
1996 850 wagon
1996 850 wagon
2001 silverado
1996 850 sedan
1996 850 wagon
1996 850 wagon
2001 silverado
- boerence
Just in case any one is interested I finally replaced the intake manifold gasket and that fixed my missing at idle issue! My last ditch effort worked.
From the looks of it the old gasket was leaking very slightly on cylinder no. 1. On four of the cylinders the gasket was evenly pressed and centered, but on cylinder no. 1 the gasket hole was off-centered, and there was a 'new' forced bolt hole next to where the punched gasket bolt hole.
The gasket was obviously installed incorrectly somewhere along the line. I've put around 100k on the car - now good for another 100k, right?
I tried to add some pictures.
Thanks again to everyone who tried to help!
1995 850 sedan
1996 850 sedan
1996 850 wagon
1996 850 wagon
2001 silverado
1996 850 sedan
1996 850 wagon
1996 850 wagon
2001 silverado
- 21 Replies
- 3276 Views
Last post by eriscentro
- 9 Replies
- 2841 Views
- 40 Replies
- 5517 Views
Last post by kaneelschep
- 11275 Views
Last post by Homebrand
- 18 Replies
- 5820 Views
