Hey all,
First relatively cold day today here (hovering around freezing) and I drove the v70 to work this morning. I have about a 15km (10 Mile) commute. The temp gauge didn't reach the mid-point and she didn't really truly blow warm air until literally I was around the corner from work. Even then, it only happened after I did a couple spirited pulls from a light.
Thoughts on what could cause this? Is my tstat in need of replacement? Could this be a heater core issue somehow? I do get a slight maple syrup smell sometimes
1998 V70R Takes FOREVER to warm up
Garage:
1998 V70R
2006 XC90 2.5T - Family Hauler
1993 Audi S4 (Sold)
2001 VW Jetta 1.8T (Sold)
1988 Mazda 323 GTX (Sold in pieces)
1998 V70R
1993 Audi S4 (Sold)
- Year and Model: Many Volvos
- Been thanked: 75 times
The thermostat is stuck open for sure so that is where I would start. SOP is to change the ECT sensor at the same time since they are right there together. The heater core may or may not have a leak but even if it did it wouldn't cause the car to not warm up properly.
- Been thanked: 466 times
Before you replace the tstat, search forum re tricks.
- Since your car is Canadian, expect rust on the Torx bolts. Soak the Torx bolts in WD-40, PBBlaster etc. for a good week before tackling it. You may need heat.
- Get Wahler tstat, which is OEM, don't forget to replace the O-ring (which is installed as a sandwich around the tstat flange).
- The ECT: use only Volvo or SWF brand...Info in forum.
- Has thanked: 292 times
- Been thanked: 765 times
Agreed, it is the thermostat. A long torx driver is the key on those bolts, so the shaft points straight down into the recesses in the screw head, so you can seat it securely. I hold a long torx screwdriver in place with one hand and turn the handle with pliers in the other hand. Then just a typical routine works fine (spray penetrant, unscrew after 5 minutes). Don't waste even one second with WD-40 in this situation, it is near worthless as a penetrating oil. That's a typo from cn90, he probably means Liquid Wrench etc.
Maple syrup smell is a sign you should also check the heater core though I agree that it has nothing to do with the time it takes the car to heat up. Does the coolant level drop at all?
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
- 1063 Views
Last post by glasst5
- 1749 Views
Last post by jakeempero
