1998 V70 AWD key FOB intermitent
kahl
Year and Model: 2000V70XC
Been thanked: 10 times
Post by kahl »
The key FOB for this car has alway been intermitent. Depending on how hard or light you pressed the button or car may make it work. Upon disassembling the FOB I found that the battery was extremely loose in the case, meaning it fell out. What I found was two of the three tabs cast into the battery case were broken causing the battery to not be locked in its proper position. The battery case is held onto the circuit by four clips. While holding the battery in the proper configuration or position the FOB worked perfectly.
So now I am looking for someone that has a junked FOB that can pull the battery case.
Ou2mame
Year and Model: 2004 xc90
Post by Ou2mame »
Don't they have them on ebay? I bought a few on ebay to fix the broken ones that came with the car.
kahl
Post by kahl »
ebay sellers have the case and soft pad but not the battery case on the circuit board.
shiloh51933
Has thanked: 28 times
Been thanked: 17 times
Post by shiloh51933 »
kahl wrote:The key FOB for this car has alway been intermitent. Depending on how hard or light you pressed the button or car may make it work. Upon disassembling the FOB I found that the battery was extremely loose in the case, meaning it fell out. What I found was two of the three tabs cast into the battery case were broken causing the battery to not be locked in its proper position. The battery case is held onto the circuit by four clips. While holding the battery in the proper configuration or position the FOB worked perfectly.
Go to the closet pick/pull and look for one inside a junked car, I see them all the time at my local pick & pull. Like I stated it has to be a wreck yard that lets you walk around to find parts yourself and pull them yourself.
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
kahl wrote:ebay sellers have the case and soft pad but not the battery case on the circuit board.
Sounds like a job for Contact Cement! 8)
