Im installing a xemodex throttle control, and also a new radiator. This is a turbo xc70. I pulled out the radiator and ac and tubo fans together. What type of coolant should i use with new radiator? I believe oil came out of a line when i removed too...how and where do i fill that again and with what type of fluid?
Any other handy repairs that should be done now that the car is pulled apart a bit?
Thanks a lot!
99. V70xc turbo. Radiator assembly fluid types?
If you have an automatic transmission that is probably ATF (red) fluid - and you need to be careful to keep that clean.
On earlier cars the engine oil cooler was in the radiator but on your 1999 it moved to the back of the engine
- Has thanked: 2199 times
In terms of fluid, you will need to check which ATF to use in your car as there are 2 types. Check the handbook for this.
Personally I prefer to use Volvo coolant fluid, but others use generic, but I can't recommend which ones work.
Klausc
- Year and Model: 1995 855 Turbo
- Has thanked: 5 times
- Been thanked: 15 times
Either Volvo or Zerex G05, Volvo is blue and Zerex is gold colored antifreeze. I would completely drain the antifreeze before putting in new stuff.
If some ATF leaked out from the driver's side of the radiator, I wouldn't worry too much. there is about 1/2 quart in the ATF cooler and that shouldn't make any difference to a 9 quart system. If you have a 5 speed autobox, the ATF is 3309, otherwise you can use DEX/MERC equivilent.
Klaus
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
- 601 Views
Last post by Luigi74
- 701 Views
Last post by DEMonte1997
- 604 Views
Last post by FLXC90
- 1350 Views
Last post by erikv11
- 14 Replies
- 2261 Views
Last post by PeteB
