So I am fairly certain now I have a warped flywheel, the problem started a few months ago and I first tried to ignore it. From releasing the clutch in first gear there is a engine shudder, it seems worse when hot...there is also a shudder when down shifting to 2nd. I was hoping it was the engine mounts and checked the top stabilizer finding the firewall mount had completely failed.
New firewall mount installed and the shudder was reduced but still there so I replaced the gearbox link brace and also the main two mounts, the rear mount had also failed. The rear mount on a turbo car is really difficult to replace, I had to remove the bracket because the turbo almost sits ontop of the mount...anyway a very little shudder remains if I feather the clutch..if I give it some gas and let the clutch out fast its ok but will sometime get tyre spin on a hill.
here is a pic of the rear mount that had failed, the massive hole wasn't visable from under the car and cant be seen from top because of the turbo.
1998 v70 warped flywheel?
- darylrobert
- Year and Model: V70 240 740t xc70
- Has thanked: 6 times
- Been thanked: 44 times
- Year and Model: Many Volvos
- Been thanked: 76 times
How many miles (km) are on the car? I got about 236k miles (380k km) out of my first clutch but in my case it was the throwout bearing that failed. The clutch was almost to the rivets anyway.
What usually makes them grabby like that is contamination from something like a leaky rear main seal or an input shaft seal on the transmission itself. In any case the fix is always the same, replace the clutch, throwout bearing, and the pressure plate. At that time I always replace the RMS even if it isn't leaking and get the flywheel surfaced. If there was contamination the source would need to be located with certainty and the leak fixed. On a '98 you have an internal slave cylinder and that too could be leaking a bit but you should have noticed that since you would need to top off the brake fluid regularly.
- regent
- Year and Model: 2015 XC60 T5
- Has thanked: 2 times
- Been thanked: 12 times
+1 on the oil-contaminated clutch disk.
The axial (throw) bearing and the release bearing are probably gone at this mileage.
I have never seen a warped flywheel to be the cause of your symptoms. In fact, if it were that much warped to create shudder, it would also have axial imbalance sufficient to cause engine vibrations even with the clutch released.
On my earlier car (the 340 DL rear wheel drive), I had a failing prop shaft (worn splines at the clutch) that started with slight shudder upon take off which gradually worsened until eventually the splines gave in completely and left me stranded (very luckily) about 100 meters from my house
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired
1987 340 DL - retired
2015 BMW 335i
- 23 Replies
- 8645 Views
Last post by jonesg
- 14 Replies
- 2325 Views
Last post by jimmy57
- 11 Replies
- 2286 Views
Last post by erikv11
- 249 Views
Last post by chris11211
- 7292 Views
Last post by belskee
