I need to replace the lower engine torque rod on my '98 V70R. It's the mount from sub-frame, to transmission. Looking around it is part number 9470836 which is discontinued. FCP has an aftermarket unit from Rein, but I haven't read anything good about them. I did find a Corteco one on PartsGeek, and a Hutchinson on eEuroparts. There is conflicting information as to fitment on FWD vs AWD vehicles.
Can anyone confirm fitment and make a recommendation to manufacturer?
Thank you.
Lower Engine Torque Rod Discontinued, Recommendations?
- Been thanked: 504 times
PN 9470836 fits both FWD and AWD V70.
http://www.volvopartswarehouse.com/p/Vo ... 70836.html
I am not a fan of Pro Part Sweden (Chinese stuff anyway), however, if you go to ebay and search, you will see PPS torque rod mount for $33 and it is all polyurethane. So, it seems like a good part.
Otherwise, search for Hutchinson brand.
Big Will
- Year and Model: 1998 V70 AWD
Have they changed the mount recently? The back of the mount (the bracket with the smaller bushing) has a slightly different orientation of the bolt holes on the AWD version. You can machine it a bit to make the FWD version fit though or use the bracket from your old AWD mount and install a new poly bushing.
98 V70 AWD - M58 Gearbox - Beüst custome tune, 20T turbo w/angled exhaust housing, Green injectors, Öhlins Roadholding Suspension, B MAC Built Engine
Do you know where I could purchase a poly bushing that would fit in the smaller section? IPd has one for the larger section, though it doesn't show as compatible with the AWD vehicles. Though I doubt the actual bushings are a different size.Big Will wrote:...use the bracket from your old AWD mount and install a new poly bushing.
Big Will
Sorry, just seeing this now. Glad you found it.
- 1359 Views
- 2180 Views
Last post by Clemens
- 1166 Views
Last post by Sommerfeldt
- 1337 Views
Last post by Peevarino
- 1404 Views
Last post by pgill
