1998 S70 Popping noises from front during tight turns
ferocity02
Year and Model: 1998 S70 GLT
Been thanked: 14 times
Post by ferocity02 »
My S70 has developed some odd popping, clunking, creaking noises when doing tight U-turns. I have tried to pinpoint the noises but cannot seem to find it. About 10k ago I replaced the lower control arms (Hamburg Technic brand, $85 for the pair) which came with swaybar links. I also replaced the upper strut mounts w/ spring seat and bearings (unknown brand, $90 for the set). The rest of the front suspension is stock with 187k miles.
After installing these parts the front end wasn't making any noises. But then overtime it has developed these nasty sounds.
I know it's hard to guess what the issue could be but I was wondering if there are common problem parts to check first.
Also, I would not put it past the LCA's to be shot already. They were dirt cheap and the bolts it came with sheared off within 100 miles of the install.
Ou2mame
Year and Model: 2004 xc90
Post by Ou2mame »
Cv joint?
RussB
Year and Model: '00 S70, '04 S60
Has thanked: 3 times
Post by RussB »
Tie rod ends?
Go to a vacant parking lot, open the hood and do some tight turns. When it pops, see if the top of the strut moves. An assistant can listen and maybe tell the general area of the noise.
I had el-cheapo strut mounts fail in a short amount of time. FCP replaced them with factory Volvo parts years ago
ferocity02
Ou2mame wrote:Cv joint?
I recently replaced the CV boots on the left side and the CV joints seems to be good. I cleaned them out and repacked them with grease. This popping was happening before and after this.
The popping seems to be coming from both sides and only happens when the suspension is loaded. I had jacked up the front end and turned the wheels and wasn't able to recreate the sound. Everything appears tight.
RussB
Post by RussB »
Sounds like end links...
obayha
Year and Model: V70 1999 Base
Post by obayha »
Not ruling out the parts you have replaced in the past, but I was thinking CV joints also. Your other parts tend to make noise as bounce happens, the turning of the car indicates possible joints. I am having the bouncing noise right now and will be replacing those parts that you have mentioned, soon. Check the replaced parts for being loose, as mine on another came loose and did creak some.
Shane
1998 V70 T5 331,000 :( Her last day was on 3 cylinders.
New to me 1999 V70 NA 163,000 Now at 217,000
2006 V70 2.5T in driveway (WIFE'S)
1982 Toyota FJ40 Land Cruiser
Been thanked: 472 times
Post by cn90 »
Hamburg Technic is the correct answer (if you have to do a multiple-choice exam) lol...
Stick to Lemforder or Moog.
