2005 Volvo s60 Trans fluid in the Coolant
So this is the story. I keep loosing coolant with no leak and I just kept filling it up. When I went to fill it up on Sunday I noticed brown what I think was transmission fluid in the resovoir container. It had that smell of transmission fluid. So I ordered a new radiator and coolant and transmission fluid thinking there would be a ton of coolant in the transmission and that is where my coolant has been going. Today I drained the transmission from the plug and I got a little over a gallon of fluid out and no evidence of antifreeze or water mixed with the oil. I am confused. First I am only supposed to get 3.5 qts out of that plug right? I did have the car on a hill is that why so much came out or is there antifreeze mixed with the trans fluid and I can't see it? I didn't think trans fluid and water would mix. So, where did all my coolant leak to and why did I get so much trans fluid out? Any help would be great guys I know that was a long post I am just beside myself.
Reason: Please read forum posting rules about titles. Thank you.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Can't answer were all the coolant has gone, but sure after installing the new radiator, I would flush the transmission as shown in Youtube videos through the return line from the radiator and fill it with fresh 3309 type fluid. Better not take chances as these transmissions are sensitive when it comes with the fluid.
- Been thanked: 504 times
I am trying to roubleshooting a very very slow coolant loss, 1/2 cup every 2-3 months/2K-3K miles etc.
I have a question re P2 radiator design: the 2 sections (coolant vs ATF passages): are they bullet-proof?
In other words, is there a possibility for the 2 passages to fail and connect with each other, causing ATF
---> cooling system vs coolant ---> transmission?
PS: Some BMWs years ago had this issue of ATF and Coolant mixing, courtesy of bad radiator!
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 534 times
possible but far more likely to be the coolant bottle, i just changed mine after finding a tiny leak on the seam, i saw tiny bubbles.cn90 wrote: 13 Apr 2024, 12:56 I am trying to roubleshooting a very very slow coolant loss, 1/2 cup every 2-3 months/2K-3K miles etc.
can also be the cap or hose clamp unions. .
dikidera
- Year and Model: S60 2005
- Has thanked: 68 times
- Been thanked: 187 times
Not just possible, but highly likely as well.
This is what happened to mine
How it works. During startup, the transmission starts generating pressure before the coolant system has had time to pressurize(34 psi usually) which allows then easy way for atf to get into coolant. When you shutdown the car, there is 34 psi of coolant pressure and 0 psi of transmission atf pressure allowing coolant to empty out into the transmission.
During working of the transmission, it's pressure should still be higher than that of the coolant but still, they fight each other when they are both pressurized. But mostly, it is exactly when you shutdown the car and the leftover coolant pressure starts entering the atf.
Glycol is extremely damaging to the clutch packs. When this issue happened to me I just happened to be running pure water as coolant and perhaps avoided catastrophic failure.
- 853 Views
Last post by nedqlkow
- 3518 Views
Last post by Krons
- 2438 Views
Last post by mrscullini
- 1532 Views
Last post by volvooh
- 2326 Views
Last post by cn90
