2001 V70 XC AWD Turbo misfire cylinder and P0134 error?
Tneville29
- Year and Model: V70 XC AWD Turbo
New to Volvos. I have a misfire code for cylinder 4 error as well as a P0134 error(O2 sensor no activity , bank 1, sensor 1) guessing the O2 front side is that error. Replaced the plug and coil on cylinder 4, still got both codes. I've heard a misfiring cylinder can ruin an O2 sensor, so I'm trying to tackle the misfire first. What else can cause a misfire, considering it's a new plug, boot and coil? Fuel injector? Ant and all hell is appreciated, even directing to a thread that covers this. I tried the search and it got all messed up. Tom.
Tneville29
Throwing caution to the wind (after doing a ton of research), and going with the burnt exhaust valve on cylinder 4. Can someone direct me to a thread that covers the removal and installation (step by step with required tools) for a remanufactured head removal and replacement? (Throwing in a new timing belt and probably a water pump as well?). I know it's in here, just have no idea where to look. Thanx a bunch, Tom. This site came highly recommended. I hope it holds up to the reference.
- Been thanked: 4068 times
Have you run a compression test on all cylinders Tom?
You want to run one both dry, and then with oil, to see if you can isolate valve from ring wear/ problems
I'll search for a good cylinder head thread in the VRD
mrscullini
- Year and Model: 05 XC70, 08 XC70
haven't pulled the head on a p2, but the job on my '00 was pretty straight forward. would anticipate it's a little more difficult to access the back of the motor on the p2 just because of the body changes.
but before pulling the head, i would do as abscate recommends. i had to pull my head because i burned an intake valve. when this happened, the motor ran rough at idle, like it was running on 4 cylinders (which it basically was). i can't remember, but i don't think i had a cel. at higher revs, it ran OK, which makes sense. it could build and hold some compression at high revs.
when i did my compression test, i had 0 psi. i had a hole in my valve about 1/2 the size of a pencil eraser.
how many miles? have the o2 sensors been replaced? i wouldn't be too anxious to pull the head.
- 11 Replies
- 2956 Views
Last post by Andys_Volvo
- 9 Replies
- 2865 Views
- 518 Views
Last post by VolvoKev
- 18 Replies
- 15127 Views
Last post by LadieRed
- 19 Replies
- 3332 Views
