1998 s70 THE DREADED PO301
ovlov058R
Year and Model: 850R 1996
Post by ovlov058R »
Hi every body! I have a 1998 S70 non turbo that developed a po301 code.It wants to stall out at idle low power... I changed the spark plugs and did nothing. changed the fuel injector and still did the same. Spark plug Wires were replaced not to long ago.. still the same! Last I did a compression test and it read 60 lbs! My Question to you, do you think it is a head gasket or a burnt valve? Btw The coolant tank would overflow and would go back down when shut off engine. Thoughts? Thanks
Has thanked: 1613 times
Been thanked: 4078 times
You need a compression test on all five cylinders
Cold
Hot
Hot with some oil in the cylinders.
It's easy to screw up a compression test and get bad numbers, too
regent
Year and Model: 2015 XC60 T5
Has thanked: 2 times
Been thanked: 12 times
Post by regent »
[quote="ovlov058R...The coolant tank would overflow and would go back down when shut off engine. Thoughts? Thanks[/quote]
Definite sign of compressed air (or mixture) going into the cooling system. Do the compression test as abscate advised or else if you run it like this you may blow a coolant hose and end up spending more $$$.
Don't ask me how I know... :(
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired :(
1987 340 DL - retired :(
ovlov058R
Post by ovlov058R »
Thanks for your help I'll try it again
