Hi all,
I am having an issue with a siren not sounding when alarm is set off. All other components operate normally. Should I just go ahead and try to replace it or there are some other diagnostics to run before shelling out $300.00 plus?
Thanks in advance.
2006 xc 70 alarm issue
fields 100
- Year and Model: s 60 T-5 2013
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Given it's a 2006, there is a chance only the battery inside the siren is toasted. I'd try removing the module, split it open, clean the circuit board and install a new battery if the board is not yet melted. The other option is to just disconnect the module and leave the car without alarm.
fields 100
Thanks so much for reply. Hopefully it IS a battery.
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
It is a battery. Doomed to failed design (battery leaks electrolyte over electronics). Don't buy used, they all suffer the same problem. Either new siren, or repair your own (~$12 for a new battery plus some work).
http://www.volvoxc.com/forums/showthrea ... went-south
Siren is much easier to get to through headlight. Bumper needs to come off.
- 4051 Views
Last post by ZootAllures
- 1896 Views
Last post by jonesg
- 2229 Views
Last post by Sailsman
- 2567 Views
Last post by oaktown
- 1313 Views
Last post by Ou2mame
