1999 Volvo S80 ABS Module Replaced ebay used.
Siekmann551+
Year and Model: S80 1999
Post by Siekmann551+ »
Well here we go . Replaced ABS module used ebay . All part #s match up . I had the battery disconnect 3 days waiting for part . Started right up running perfect . Waited 10 min to warm up and went for the little drive for reset of how I drive or what ever it's doing . Same thing pops up ABS / Brake Triangle with car on right / Stop ASAP on left . Turned off car won't restart. Also tach & speedometer wet out during drive along with temp gauge. What do I go to next . I'm lost now . And poor to say the least . :?
Matty Moo
Year and Model: 850, 1996
Been thanked: 30 times
Post by Matty Moo »
1. What was the part number on the original?
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
Siekmann551+
8619538
Siekmann551+
Is there any way to disable this ? It runs beautiful then ABS Brake flash on ...... turn it off ..... No Start...
Brakes worked fine when I'm driving. Am I nuts ?
doublebug
Year and Model: XC90 2007 D5
Been thanked: 7 times
Post by doublebug »
CEM can be your issue.
If you have questions about Volvo firmware ask me. I may know an answer :)
Siekmann551+
That was replaced about 8 months ago not by me .
Siekmann551+
The module or computer I call it ... under the kick panel and then one in the engine compartment by the radiator over flow .
Matty Moo
Post by Matty Moo »
It isn't the abs module, I'll tell you that much. Something else is causing the lights to come on.
2000 s70 GLT
2014 Ram
Siekmann551+
I know the previous owner rewired the rear . It's got to be a short somewhere where the start point is baffles me . Maybe the 4 sensors on the wheels? I think I can do that one at a time being cost prevented for me . Any thoughts on that ?
Matty Moo
Post by Matty Moo »
It's quicker and less money to get a scan done to read the codes from the abs module.
2000 s70 GLT
2014 Ram
