1998 V70 Spark plugs look dirty, but are they normal?
Spark Plug Wars - What's Best for Your Volvo
- theWIFES_S70
- Has thanked: 61 times
- Been thanked: 37 times
Hey, just a quick question and clarification. Is it commonly suggested around here that you should always run the Volvo OEM Turbo spark plugs in all N/A P80s?
Retired:
2015 Volvo S60, T5, 85K
brunocerous
- Year and Model: 1998 V70
- Has thanked: 303 times
- Been thanked: 43 times
Thanks so much for the tip. I was a little shocked to find Denso plugs in there and definitely won't be buying them. I just ordered an NGK set and will pick them up later today! I'll update after I install and try them out.cn90 wrote:Stay away from Denso plugs, they are known to break the tip off (Search Volvospeed).
- Switch to NGK Iridium BKR6EIX and you will never look back.
- Although Iridium plug is $7/each (Advance Auto Parts), Iridium easily lasts some 100K. The car will run very smoothly, you may see better fuel mileage.
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
rguzz
- Year and Model: 1996 850 turbo
- Been thanked: 25 times
I'm going to go out on a limb and maintain that replacing the plugs will be a quick fix and that they will foul again. I like the leaky injector suggestion. How old are they? Is CTS a zillion miles old? Any evidence aside from the plug appearance that the car has been running rich? I suppose the non oem plugs you have in there could be entirely responsible for what you are seeing but I'm suspicious there is a yet to be an underlying issue. Admittedly, I'd probably do just what you are doing, but would maintain a nagging suspicion that there is still something awry. Good to get lucky, though!
- RussB
- Year and Model: '00 S70, '04 S60
- Has thanked: 3 times
How old are the spark plug wires, cap & rotor? Bougicord & Bosch?
Is the ignition coil strong?
Does the car burn any oil?
Those are the proper plugs. It's not a spark plug issue...heck, the plugs aren't THAT bad
Sommerfeldt
- Year and Model: 2018 S90 T8
- Has thanked: 55 times
- Been thanked: 42 times
They're Volvo plugs, no question about that, but I thought there was a general agreement that the multi electrode plugs are not these engines' favorites...RussB wrote:Those are the proper plugs. It's not a spark plug issue...heck, the plugs aren't THAT bad
Those are the worst plugs I've seen out of a Volvo after just 2 months of running.
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
- dosbricks
- Been thanked: 4 times
+1RussB wrote: Those are the proper plugs. It's not a spark plug issue...heck, the plugs aren't THAT bad
Three ground prongs are Volvo spec for an NA. NA runs well on them. I change about every 30k.
Single ground copper are for turbo.
Light tan ashy residue is desirable = fuel/air mixture correct. Those look like the engine is running rich.
- Has thanked: 312 times
- Been thanked: 818 times
Thread is a little all over the place ...
- no, it is not good practice to use the turbo plugs in a non-turbo car. Not recommended at all, ever. The first few responses in this thread seem to have not noticed the car is NA.
- yes, the OEM plug for the NA is 3-prong
- the OEM plugs are about $5 each and proven to be superb over the last 20 years, how is that overpriced compared to a $7 iridium??? You will easily get 40k from the OEM, 3-prong plug.
- agreed, there is likely no plug issue at all here, the new plugs are just fine no need to replace.
Among other things the residue on those few plugs could be oil, due to leaky valve stem seals. Any smoke when revving after prolonged idle, or on startup? Injector idea is reasonable but you can't clean them yourself.
- RussB
As are ALL spark plug threads. Brings out the crazy in people!erikv11 wrote:Thread is a little all over the place ...
It looks like oil to me, but the condition of the rest of the ignition system must be at "stage zero" too.erikv11 wrote:- no, it is not good practice to use the turbo plugs in a non-turbo car. Not recommended at all, ever. The first few responses in this thread seem to have not noticed the car is NA.
- Has thanked: 2866 times
- Been thanked: 1332 times
- 1168 Views
Last post by E Showell
- 1869 Views
Last post by liquidBlack
- 4166 Views
- 1066 Views
Last post by jmscdgn
- 11 Replies
- 935 Views
Last post by vtl
