Howdy, been having this issue for some time now. Problem is intermittent. It seems like it goes away for a bit whenever I do work on the car, but without fail comes back.
Idle dips down to 600-700rpms during the last few seconds of braking (around 10mph), and then goes right back up to 900 where it should be, once completely stopped. Issue only happens when in drive, decelerating in neutral does not produce the symptom. No error codes, CEL is not lit. Has not stalled out when exhibiting symptom. Can't tell if it feels like idle is dipping due to lack of fuel, or lack of air.
My best guess is that it's an electrical issue, but I'm not sure where to look. Buddy of mine thinks its a vac leak somewhere. All vacuum lines to and from the turbo have been recently replaced. Haven't replaced any other vacuum lines or check valves though.
I know this is a common ETM issue, but the 98 V70s do not have an ETM. As far as I know, the ETM was introduced in 1999.
Any help would be appreciated. Thanks!
98 V70 AWD-Idle dip when decelerating
benpineapple
- Year and Model: '06 V50 T5, '13 XC90
- Has thanked: 5 times
- Been thanked: 4 times
2006 V50 T5 [190,xxxM]
2013 XC90 FWD [80,xxxM]
2001 V70 X/C AWD [sold at 120xxxM],1998 V70 AWD [RIP at 249,255M], 1990 240 [SOLD at 220xxxM]
Vacuum leak.
crismit125
- Year and Model: 1998 V70 GLT
I have this EXACT issue with my 98 glt, you have explained it perfectly. I have checked all my intake and turbo vacuum lines and they are all good, also the evap lines around the engine bay. I also tried a second IAC (idle air control valve) which fixed the issue for a day but it then came back. Soon when i change my oil and the car is off the ground im going to check the evap line that runs by the fuel filter in the right rear of the car. i'll be following this thread and update you on what i find.
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
I've lived with this issue for years. Search "Campaign 81" on this site. It may be the answer. I haven't yet had it done to my car and am not sure the local dealership could still do it. I do know it would cost around $165 to have done so, for now, I choose to live with it. (Apparently, Campaign 81 is a Motronic software update).
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- 22 Replies
- 10965 Views
Last post by matthew1
- 19 Replies
- 7377 Views
Last post by EngineeringBloke
- 12 Replies
- 2516 Views
Last post by Tarek80
- 2474 Views
Last post by oragex
- 743 Views
