1996 volvo 850 headlights blinking instead of turn signals Topic is solved
zandershope_
Year and Model: volvo 850 1996
Post by zandershope_ »
Hello i was wondering if someone could help me. I just bought my 96 volvo 850 from a mechanics shop close to where i live. The problem is when u try to use a blinker the headlights blink instead of the blinkers. On the top back of the steering column there is a black wire harness sticking out not plugged into anything. The mechanic said he put in a new relay and switch for the blinkers but that theres a part missing on the steering column. Please help thank you
Been thanked: 504 times
Post by cn90 »
Search forum for ignition switch wiring scheme (color codes).
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
Why won't the mechanic/seller fix it?
zandershope_
He was working on it for a month he said it was doing that when he bought it and he doesn't know what's missing. He doesn't know much about foreign cars.
zandershope_
Other than that the car drives great.
regent
Year and Model: 2015 XC60 T5
Has thanked: 2 times
Been thanked: 12 times
Post by regent »
zandershope_ wrote:...He doesn't know much about foreign cars.
But he sold you one with blinking headlights?
This must be none other than an unmarked Police vehicle :D
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired :(
1987 340 DL - retired :(
Been thanked: 4071 times
These sort of hacks are really tough to fix on the Internet. Definitely post some pictures.
Scan the forum on Mechanics to see if there is someone in your area who knows these cars
You should expect to pay about 5 hours work minimum to isolate botched wiring, just labor.
Post by cn90 »
Search forum for electrical diagram:
3/3: Switch, turn signal/high and low beams
3/6: Switch, hazard lights with flasher relay
You can find relays 3/3 and 3/6 at local junk yard.
Make sure you label which is which (yours vs junk yard parts) before swapping.
The only place that uses Volvo 850 as police cars is the UK. There may be more but that is what I see.
BEJinFbk
Post by BEJinFbk »
I don't know if this will get you where you want to go,
but coincidently, the headlights and the turn signals
share a grounding point up in the front left, near the
battery. Follow the blue ground wire from the battery.
Just sayin'...
zandershope_
Also i wanted to ask , how do i know if my volvo is a 850? I have to finish paying if off before I can get the title. From my research the 850 was made between 92 and 96.
