This is my right rear tail light lens, notice there are only two holes whereas, the left lens has three holes. Both R & L plugs have three sockets, do I need to drill the third hole? Anyone run across this before? Thank you!
R/ Greg
1998 S70 Rear Lens only has 2 holes for light bulbs
crlande
- Year and Model: 240DL;850;S70
- Been thanked: 36 times
From the owners manual:
The rear fog light (located in the driver's side tail light cluster) is considerably brighter than the normal tail lights and should be used only when the atmospheric conditions, such as fog, rain, snow, smoke or dust reduce the daytime or nighttime visibility of other vehicles to less than 500 ft (150 meters).
For the rear fog light to function, the low beam headlights must be switched on.
* By design, there is one rear foglight only, located in the driver's side tail light cluster.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Why would a 18 year old car all of the sudden need a hole drilled in the tail light assembly?connergg wrote: This is my right rear tail light lens, notice there are only two holes whereas, the left lens has three holes. Both R & L plugs have three sockets, do I need to drill the third hole? Anyone run across this before? Thank you!
R/ Greg
- Year and Model: Many Volvos
- Been thanked: 76 times
My 740s had them on both sides. It was a great way to get someone that was riding your bumper to back off.
- Been thanked: 4068 times
Fog U 2 lights, shirley
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Much better visibillity in foggy conditions,improved security in heavy fog conditions.rspi wrote:...Why would a 18 year old car all of the sudden need a hole drilled in the tail light assembly?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
Persons driving some brands that have them on both sides use them to melt both lamp assemblies instead of only one when they leave switch on 100% of the time.
- 824 Views
Last post by rspi
- 5135 Views
Last post by AVOIT17
- 22 Replies
- 6777 Views
- 1221 Views
Last post by slickdizzy
- 1016 Views
Last post by E Showell
