Hey. Yesterday I was replacing the driver side wheel hub/assembly and the passenger side cv axle. The work on the drivers side went smoothly, I was hoping to replace that CV axle as well but couldn't free it from the transmission. The driver side CV axle was in good condition so I wasn't too upset.
But the passenger side didn't go too great. I replaced the CV axle, lost 6 oz of fluid in the process, and got it back together. But I broke one of the three bolts for the strut mounting point when I was torquing it down (25 ft-lbs). I was able to get the nut back on, but as you can see its only grabbing two or three threads.
How big of an issue is this? I was hoping to be able to make it home for Thanksgiving (5 hr drive) and don't have a ton of time to work on this before then. It didn't seem too bad to replace that bearing/mount, I'll just have to get a spring compressor from HF & work in the dark. Any tips when replacing the mount? Should I replace the spring seat as well? If I do do this before thanksgiving I'll have to go with generic napa/autozone parts and won't be able to order from FCP. Would that be an issue as well? Thanks for the input.
1998 S70 Broken Strut Mounting Bracket Bolt
- Been thanked: 504 times
With only 2 nuts keeping the Spring Seat in place, it is probably safe to drive at speed below 60mph.
Options:
a. Ghetto repair until you have time to do the proper job: drill the remaining stud out and use standard nuts and bolts to hold the Spring Seat in place.
b. Do the proper job: overhaul the suspension (new Strut...I use Bilstein TC, Spring Seat etc. etc.).
I wrote a suspension overhaul a while back in forum, you can search for it.
Options:
Yea I figured it would be safe at low speeds. I don't have the tools to drill out the stud (no drill) but I'll look to see if I can press it out at all.
I saw your writeup actually, it was good and thorough.
- Been thanked: 4068 times
The load of the car is taken by the strut tower, not those bolts. They just locate the strut and keep it in the right place. safe to drive, paying attention to the other nuts and hardware.
Replace all of the front suspension parts if you want to drive the car for a long time
benpineapple
- Year and Model: '06 V50 T5, '13 XC90
- Has thanked: 5 times
- Been thanked: 4 times
I'm not trying to be a tool snob, but don't get one from them. I have had breaker bars snap in half from HF. Don't trust their tools. Using a spring compressor is a dangerous task, you're going to want to make sure you use the best components possible when compressing it. You can always loan a much higher quality one from AutoZone or some such.styoung94 wrote:I'll just have to get a spring compressor from HF & work in the dark.
In regards to what you want to replace versus keep, it's not a bad idea to replace as much as possible while you've got the suspension components out. Definitely replace the shock mount while you're at it.
2006 V50 T5 [190,xxxM]
2013 XC90 FWD [80,xxxM]
2001 V70 X/C AWD [sold at 120xxxM],1998 V70 AWD [RIP at 249,255M], 1990 240 [SOLD at 220xxxM]
youngin9494
- Year and Model: S70 2000
Didn't remove it completely. Just loosened the top a little and then removed the bottom two bolts. It was they way they did it in the fcp video (maybe it was the 1-A auto I can't remember). It defiantly gave me more room to work than just removing the frame side of the control arms.RussB wrote:Why did you remove the strut to replace the axle?
benpineapple wrote:I'm not trying to be a tool snob, but don't get one from them. I have had breaker bars snap in half from HF. Don't trust their tools. Using a spring compressor is a dangerous task, you're going to want to make sure you use the best components possible when compressing it. You can always loan a much higher quality one from AutoZone or some such.styoung94 wrote:I'll just have to get a spring compressor from HF & work in the dark.
Yea I understand, it turns out my cousin has one anyway so I'll just be using his the weekend after thanksgiving.
I noticed a slight leak from the passenger side CV axle seal (95% sure its from there), so I ordered a new one of those along with flexible brake lines and new strut spring seat & mount. All that should be here tomorrow so I'll do it the weekend after thanksgiving. Anyone have any advice for replacing that seal? It looks like it just comes out, but I can't find a ton of info on its replacement.
- dosbricks
What kahl said. A very large screwdriver will pop it right out. Just be sure not to scratch its mounting surface on the transaxle.
- 730 Views
Last post by Seaway
- 1814 Views
Last post by Ou2mame
- 542 Views
- 579 Views
Last post by Mr. Detail
- 2834 Views
Last post by Vova585
