I need to tighten the rear axle hub-nut and cannot find the torque settings. In fact, can't find the value for the front either (not that I need that one).
Normally it is a pre-load (140Nm?) and then an angle torque 60/90 degrees or something like that. Can anyone help as I want to drop the car back on the ground and want to get the 1st value at least.
Thanks!
2000 V70R - AWD Rear Spring axle nut torque?
- Has thanked: 1850 times
- Been thanked: 1710 times
I'll answer my own question again. After a lot of searching, the answer is:
1) Torque to 140Nm
2) Tighten further by 60 degrees.
1) Torque to 140Nm
